How Are the Staggered 4matics Holding Up?
I want to go 255/35/19 285/30/19 for thr extra rubber and load rating but it's off by 0.2". I can go 245/35 285/30 which according to Hankook are very close to identical, but the load rating is a 91. I also heard that preface lift w212s transfer cases do not have the tolerance the newer 4matics have, any truth to that? I can't imagine in 2012 they didn't consider tread wear tolerances, but in 2013 they did.
What you want to compare are rpm (rounds per mile) as this is what your car drive-train will see.
255/35 is 26" with 775 rpm
285/30 is 25.8" with 782 rpm
So I'm confused, tire size calculators say 245 285 are off by 1 rpm, but Hankooks spec says 24 difference. Why would a time with almost the same circumstance have such a different rpm?
I have seen 2 different model tires from the same manufacturer in the same nominal size having rpm different by 5%.
That is why manufacturers list rpm.
Tire size calculators can give your rough idea, but are garbage for making staggered set up.
Some tires are design with stiff sidewalls for load capacity, some are soft for comfort.
Than you have centrifugal forces, that are harder to observe.
I have never seen MB making official statement how much % of rpm difference the ESP and traction will tolerate, but common experience says it is less than 3.
Take a look at donut spares on ML class. I drove on one of them for 60 miles on different roads and had traction light coming only couple of times on sharp turn.
This set F&R has 2.7% difference. Sometime my traction lights up during cornering.
I also have another set Pirelli PZERO NERO GT 245/30/20, 285/25/20
F&R difference is 0.7%
Runs perfectly fine no traction lights up, unless I go WOT.
I learned from a member here...lol
http://www.miata.net/garage/tirecalc.html
