Sponsored by: CARiD
How to remove a 2013 E250 coupe Antenna?
Old Apr 20, 2017 | 05:19 AM
Oliver Ramsey's Avatar
E250 coupe
Hello
Does anyone have a guide or know how to remove the antenna on a 2013 E250 coupe?
Im looking to wrap the roof and shark fin antenna, but just wondered if..
• you need to remove the whole headlining
• if you can just remove the rear light and get to it
thanks
Old Apr 20, 2017 | 10:22 AM
E250 coupe
If its of any use to anyone, you can remove the rear reading light in the E250 coupe and un-screw the nut holding the shark fin on the car. You can then un-screw the cover metal circuit board so it comes away from the plastic cover.
By doing this, it allows you to make a smaller hole in the roof wrap to pass the antenna through. Also it allows you to wrap the shark fin.
Fingers crossed that will all work!
Old Apr 20, 2017 | 11:48 AM
belarus27's Avatar
2010 e550 p2
i dont know how different it is in coupes , but when i was wrapping my roof , i couldnt completely remove the fin , cuz its held in there by 3 wires , that needed to be disconnected , in the middle of right front and rear roof headliner (was too lazy to do the extra work)
you can kinda pull on it though to get it up a bit higher to make the wrapping a bit easier
