INTELLIGENT SYSTEM LIGHTING
"The cornering light function improves the illumination of the road over a wide angle in the direction you are turning, enabling better visibility in tight bends, for example. It can only be activated when the low-beam headlamps are switched on."
Active:
-if you are driving at speeds below 25 mph (40 km/h) and switch on the turn signal or turn the steering wheel
-if you are driving at speeds between 25 mph(40 km/h) and 45 mph (70 km/h) and turn the steering wheel
Not active: if you are driving at speeds above 25 mph (40 km/h) or switch off the turn signal or turn the steering wheel to the straight-ahead position.
The cornering lamp may remain lit for a short time, but is automatically switched off after no more than three minutes."
hope that helps
