Sponsored by: CARiD
A/C smell
Old May 15, 2017 | 09:58 AM
majids's Avatar
E 300, 2017
A/C smell
My new 2017 E class has a bad smell coming from A/C (vinegar like or dirty sock smell). Took it to the dealer but they dismissed the issue. Any suggestions?
Old May 15, 2017 | 11:22 AM
sears1234's Avatar
GLC, EQE SUV
try this:
It works for me.
Old May 15, 2017 | 11:39 AM
RA72825's Avatar
I have never heard of this in a Mercedes Benz.
that is sarcasm btw
Old May 15, 2017 | 06:32 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
How long have you had the car? Seems odd to get a smell on a new car.
I get a similar smell about 12-18 months after a cabin filter change on my 2011. Lysol is a temporary fix for me. The dealer has multiple procedures to address this issue - they can spray the ducts, spray the evap coil directly, change the filter, etc. They are just blowing you off.
Old May 15, 2017 | 07:53 PM
teksurv's Avatar
2024 EQE 500
As I have learned with Mercedes cars, leave them on Auto, set the temp you want, don't mess with the A/C button.
Old May 15, 2017 | 07:58 PM
PLINYELDER's Avatar
2023 GLE 450
I always run my fan at high speed after turning the Ac off before I park my car. I have done this with all my cars to prevent any moisture from causing smells. May be in my head, but my ac never smells in any of my cars.
Old May 15, 2017 | 08:27 PM
degeja's Avatar
2016 E350 Sedan SPort
forgot to leave the AC on auto for a while or using it-
first time on smelled like dog doo.
Old May 15, 2017 | 08:50 PM
jumpman726's Avatar
2024 E350
Here's a video I found on YouTube that specifically shows how to get rid of the AC odor on a W212 E-Class. Looks messy though. The video also shows you how to replace the cabin air filter.
Old May 16, 2017 | 06:00 AM
besh87's Avatar
2013 e350
Same thing with my 2011 and 2013, no idea why it's happening...
Old May 16, 2017 | 10:42 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Evaporator coils need to defrost (just like your refrigerator does)
I never had the issue in CA or NV, but in high-humid areas, when you turn off the engine with AC on, the frost will drip down the ducts, filters and whatever else and left overnight will grew mildew.
Good idea in those climates it turn AC off 2-3 minutes before reaching home in the afternoon.
Old May 16, 2017 | 11:14 AM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Had it on my C class. Dealer fixed it with cleaning and filter change.
Old May 17, 2017 | 03:04 AM
belarus27's Avatar
2010 e550 p2
Had it happening to mine last year...
Tried lysol and it helped only for a lil bit.
After that bought a new filter off ebay no smell eversince.
Problem solved.
Old Oct 31, 2017 | 01:23 PM
fosterelli's Avatar
2014 E-350
FWIW I fixed my smell - posting on a couple of these related threads in case anyone needs help. Used professional equipment (Liqui-Moly A/C stuff). Didn't drill, just removed panel under glovebox, removed cabin filter, used tube and sprayed on evaporator. 15 minutes tops, no smells whatsoever (I had bad smells like others, plus the smell left behind from my melting speakers...guessing that smell was trapped on filter). Anyway, no smells, and the equipment is reusable so I have enough fluid to do it several more times if the smells ever return. Or, if you're in the Houston area, I'll hook you up! PM me if you want more info or help.
Old Nov 9, 2017 | 11:28 AM
zio's Avatar
zio
The dealer has a procedure to clean it. They will also change the in cabin filter. Just had it done. It's free if you are within your original factory warranty period.
