Sponsored by: CARiD
Engine cel with code P001685
Old May 23, 2017 | 04:24 PM
adnan khandakar's Avatar
2015 e200
Need help
I Have changed the whole timing chain
Tensioner and also cam adjusters both intake and exhaust ....
It's a 2015 e250 with m274 engine
Still long self required and cel bulb comes on....
Any feedback will
Be appreciated
Adnan
Old Dec 10, 2017 | 04:31 PM
Kassem23's Avatar
E212
Hi my dear friend please i have got the same car problem i have reached a solution an
Originally Posted by adnan khandakar
Need help
Any feedback will
Be appreciated
Adnan
Old Dec 16, 2022 | 04:26 PM
7urkm3n's Avatar
W212
Have you got a solution ? What was the problem after changing these PARTS ?
Old Dec 16, 2022 | 07:43 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Post
New tensioner & VVT set on 4Cyl...
Current fault or stored such as pictured?
Bad old cam sensors or oil in harness??
Look at live data: "camshaft position angle" to confirm both (Solenoid + new VVT) are functional.
Do an oil change with recommended oil grade or thicker... as pressure drives the whole valve timing system.
Old Dec 19, 2022 | 02:37 AM
7urkm3n's Avatar
W212
I am about to give it to maintain, Its not dealership so far. The person who will work on is mechanic. My issue is P001685 camshaft adjuster(VVT) 1st bank (common issue cam intake fails).
Interesting, How to check this ?
Old Jun 20, 2023 | 02:04 PM
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 Coupe, 2013 E350 Wagon
Did this get resolved for any of you above? I am thinking it needs STAR to 'calibrate' or reset following cam adjuster swap? My car is running fine with no other alarms but this P001685...
