Sponsored by: CARiD
Identify Part(s) & solution for oil leak
Old Jul 24, 2017 | 08:00 PM
David Vilkhovoy's Avatar
mercedes-benz e350 4matic
Found an uncommon oil leak from the back of the engine a seal, hoping I can remove the plug and replace seal without purchasing a whole assembly.
pls advise if you know the specific part # and best solution. Thanks fam!
Old Jul 25, 2017 | 09:18 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
I do not have the part # just chiming in with common leaks that I've had before or have heard about on MBs. Both are in that area round about. The cam plug and centrifuge cover/plug are common areas that leak and on an NA engine they can be easy to replace. I've heard it's much more expensive and difficult on a turbo but I'm not 100% sure.
I know a replaced plug was roughly $270 at the dealer for my E550. Not sure if this helps any. Hopefully someone else can help you and point you in the right direction.
Old Jul 25, 2017 | 11:20 AM
ktr's Avatar
ktr
'12 E350 BlueTEC Sport
A 272 010 06 31
Cover for the oil separator.
Old Jul 25, 2017 | 11:28 AM
konigstiger's Avatar
'71 Pinto
Current part # 2720100631.
Attached Thumbnails Identify Part(s) & solution for oil leak-capture.jpg   Identify Part(s) & solution for oil leak-capture2.jpg
