What octane rating do you use?
My 2001 C320 had the 3.2L engine (91 octane required)... Sometime after 2005, there was a large, seasonal gas price increase, which prompted me to try a tank of 89 octane. I noticed a 10 minute period of peculiar performance as the onboard computer adjusted. Thereafter, the engine resumed its performance level as before. Curious, after a couple tanks of 89, I tried Regular 87. The car did not like 87 at all, but refueling at half tank level with 89 the performance was back to normal. I used 89 octane thereafter, until the car was sold last month. No problems at all (for 18 years).
The 3.5L in the E350 is a further development of the C320's 3.2L. The only reason I have not tried 89 in my E-Class is that I shop at Albertsons/Tom Thumb grocery stores, where I earn $1.00 off per gallon with my grocery purchases. So the price for Premium (93) minus the dollar per gallon is always less than the non-discounted pump price for midgrade (and regular, too). So, I've stuck with Premium since I acquired the car in 2018.
Each time we get a huge spike in gas prices, I'm tempted to try mid-grade 89, just to see what happens, although I seriously doubt there will be any ill effects. But so far, I've resisted.
So there, I've admitted it. Shoot me.
My 2001 C320 had the 3.2L engine (91 octane required)... Sometime after 2005, there was a large, seasonal gas price increase, which prompted me to try a tank of 89 octane. I noticed a 10 minute period of peculiar performance as the onboard computer adjusted. Thereafter, the engine resumed its performance level as before. Curious, after a couple tanks of 89, I tried Regular 87. The car did not like 87 at all, but refueling at half tank level with 89 the performance was back to normal. I used 89 octane thereafter, until the car was sold last month. No problems as all (for 18 years).
The additives are the only difference in the the two, that and the labels that say 89 on the mid grade and 93 on the super.
Also, these cars can adjust to run 89 octane, but not regular, unless its a flex-fuel car, in which case it will run on regular or E85, the gas mileage and performance will suffer, especially with E85, which is why the flex-fuel cars come with bigger gas tanks, different spark plugs and ignition coils.
With the “old fashioned” port injection fuel octane rating is very important as the fuel/air mixture sees the high compression before the ignition spark. We don’t want the fuel/air mixture to ignite before the spark so we need high octane rating of the fuel.
DI engines are a bit different for this. Fuel is not mixed in air outside the cylinder so it is only air that sees the high compression before the spark.
Fuel is injected in the high compression cylinder just at the time of the spark or just a microsecond before that. Danger for knocking is minimal regardless of the octane rating or at least way lesser problem compared to the port injection. This all makes me wonder if I should try a tank of 87 to see how it runs in my DI engine.
You basically need an engine designed to take advantage of the higher octane and that's more of a purpose built engine, using higher octane in an engine not designed to take advantage of it doesn't really do anything.
Does anyone know if this would affect the octane rating, and possibly the performance of our cars during winter months?
Also I would add the ignition and combustion cycle is different here than in Europe, I believe the flex-fuel cars here have a similar sequence to those Euro cars.
