I have problems with rear airmatic help please
Hello
Just now my car lowered both wheels in the rear.
It says in the display "vehicle rising"
waited for 5 mins and it dosnt rise.
I took off the car and I can hear the compressor working even when the engine and ignition off.
I had to disconnect the battery in order to get it to stop.
And when I connect the battery again it starts working again at once even when the vehicle is off.
Its a wagoon with air in the back and springs in the front.
Help please.
Help please.
I would have the car towed to a local shop with M-B diagnostic capabilities. I would not try driving it, as you might cause even more issues. Good Luck!
Received 1,616 Likes
2014 E550-sold 😩
Yes, get it towed. Your pump will burn out if you keep it connected, and then you will have to replace it in addition to whatever else is causing the leak (air spring, faulty air line, distribution block, etc.)
Thanks for answers.
