Retraining TPMS and service could get after service
Just did my 40,000 mile "B" service. First I reset the service counter. Great. No problems. When I go to "Service" it reads "Service A3 in 10000 miles". Great, right? Except I've driven about 35 miles since resey and it's still reading 10000 miles. Also, I recall the lettering being white. Now, it's kind of "grayed out" like a web link that's not active. Do I somehow need to activate it, or tell it to start counting down?
Second, I rotated the tires. The tire pressure graphic came up with all the numbers in the wrong spots, then changed to "tire pressure monitor active". This is totally normal. I hit the down arrow, and pressed ok on "use current pressures as new reference values". It confirmed "tire pressure system restarted" but again after that same 35 miles or so, my pressure graphic has not returned. I don't have a warning light on so I'm not terribly concerned, but do the two different service systems really take this long to respond when I confused them like this? Why isn't mileage counting down, and why can't I get my tire pressure graphic back?
Thanks,
Darel
When does the service interval start counting down?
So after you drive about 1000 miles, it'll show 9000 miles till service.
if you don't drive much, it will at some point switch to # of days till service instead of # of miles and will count down from 365 days in 5 day increments.
Thanks,
Darel
What do you guys recommend? Waiting until the 30k mi services, or...?
