Sponsored by: CARiD
e63 20x10 all around
Old Sep 2, 2017 | 12:51 AM
Cifdig's Avatar
Top Answer: 1
2007 e350 sport. 2010 350 4matic sport. Worlds first W212 E63R self built.
I've searched and it seems to be that most aren't sure what the actual limit is as far as front fitment and tire size for the e63 as far as 20" wheels go. So I did some test fitting with the next door rim shop. 20x10 et35 with a 265-30-20 will fit with in my opinion the perfect amount of poke. There's no rubbing driving straight and normal lane changes on partial turns and it clears the strut on top by 10 millimeter and clears the inner wheel barrels by 5 millimeters , then I tried a 275-30-20 and depending which name brand you use it will clear the inner side by 3 millimeter from inner tire to strut contact, the only time it will rub is on a full complete turn, the tire slightly rubs the back side of the fender liner, but with a heat gun it pushes in perfectly and stops touching. Tires do not touch fenders at all no matter how hard of a bump or turn, if you are lowered then that might be a diff issue, this is for stock height. Some of you may think it looks awful as you like the stock size setup. But some of you may like the euro mildly aggressive poke look. I purchased rotiform kps and had them powder coated to look like the stock color combo, charcoal grey with machined face. Now the tires I picked are continental extremecontact sport. They are actually 5 pounds lighter then my 19" tires, and my rims are The same weight that my stock 19x9 amg wheels are . So I moved up from 19 to 20" and managed to be roughly 4-6 pounds lighter per corner. And as you know 4-6 lbs is a great amount of weights shaved especially weight that's that far from the center of the wheels. I will have pictures up asap.
Old Oct 4, 2017 | 01:11 AM
danikkolo's Avatar
2015 e400
Are you going to sell your 19s? If yes Pm me details
Old Oct 4, 2017 | 09:22 AM
Cifdig's Avatar
Top Answer: 1
Thx for the interest but I don't
Plan on selling them. My "20 wheels were more of a
Temporary fitment until I find wheels I really love. And when I lower the car I plan on running stocks with spacers
Old Mar 16, 2020 | 04:46 PM
Juanespinoza59's Avatar
2011 Mercedes E350 w212
What’s size tire for the rear?
What did you use for the rear tire?
Old Sep 20, 2021 | 01:45 PM
kylerzinho1's Avatar
2015 E63 AMG-S
Advice on 2015 E63
I just bought a 2015 E63 and want to do the same thing with 20x10s and 35MM offset all the way around. So if I read this correctly they will fit without rubbing fenders or wheel wells?
Old Sep 20, 2021 | 07:43 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
are the roads absolutely racetrack perfect where you live and drive? /30 series tires are *brutal* on typical city streets with potholes and cracked pavement and such.
