Must say I am disappointed in MB USA
2014 E550 Black on Black
Wow, you are racking up the miles quickly. We have the same car and I have 46,000 miles. I don't have any of these brake issues and specifically looked at my brakes very closely when I swapped wheels/tires for winter a couple weeks ago. All is good. Are you tracking this thing? LOL
Ok, good. Not all parts are created equal and hopefully you will get back on the road with no issues moving forward!
Received 1,736 Likes
1922 Ford Model T / no OBD
They don't have to be warped.
I have seen it once in my life and that was MB rotor that had different material density.
You could see different colors in about 3 spots on the rotors. After few thousands miles, the pads wear out softer material, when the harder was catching the pads.
That can be done only by inconsistent casting.
Never have seen that flaw in Chinese rotors
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
W212 E-class, W211 E-class, F10 5-Series
Ugh here we go again. 8,000 miles since the brakes and rotors were replaced and guess what, the brakes are pulsating again. My car is at a new dealership (MB of Springfield) for it's A service and I explained everything to the service tech. I told them the brakes were warped when I took ownership of the car at 21,000 miles, MB replace them under warranty at 32,000 miles, now at 40,000 miles they feel warped again. I explained to them this has to be a manufacturer defect in the rotors themselves. If anyone has any documentation other than what was already given to me by konigstiger regarding defective 2014 E550 brakes/rotors I would greatly appreciate it.
This may be a question for konigstiger too: but does this issue only happen to E550's? Does it affect E350's also? Can you share the documentation given to you by konigstiger regarding defective 2014 brakes/rotors? I'll need leverage when I speak to my SA.
When I purchased my CPO 2011 E550 I had a friend run a VMI to see what the dealer actually did to the car prepping it for CPO. The VMI indicated that the rotors and pads had been replaced. After about 6000 miles the brakes were shuttering. I took the car back to the dealer and told them it was unacceptable and that the VMI indicated they had just replaced the rotors. The dealer agreed to replace them again. This time they lasted about 20,000 miles before they started shuttering again but much worse than the first time. I decided to replace them myself with a EPC rotors and pads. So far, so good, but time will tell. I have owned a lot of cars in my 61 years and have never had brake rotors warp under normal every day driving. I expect better from MB.
