Sponsored by: CARiD
HELP needed
Old Sep 20, 2017 | 11:19 PM
vvadim66's Avatar
W221 S550
Question HELP needed
Hi all.
I have 2010 W212.
The issue I can't run car.
1. I can lock/unlock car with remote.
2. I can turn key to position 2, but nothing happened. Cluster still dark.
3. No error codes.
4. I did check Pre-fuse box. It is OK
5. Power on ECU, YES
6. no power of FUSE 6.
7. Check all power distribution. OK
Any ideas what it can be?
Thank you.
Old Sep 21, 2017 | 01:25 PM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
Have you verified the battery condition? It may show 12 volts but not have enough amperage to power much of anything else.
Old Sep 21, 2017 | 01:34 PM
apg231's Avatar
2019 S450 Silver w/ black interior
http://www.autogenius.info/mercedes-...e-box-diagram/
You said no power to Fuse 6 correct? Fuse 6 controls the engine electronics, fuel pump and starter according to the above fuse box diagram.
Old Sep 21, 2017 | 02:15 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by vvadim66
2010 W212 issue I can't run car no power of FUSE 6
F6 = engine control unit, theft relevant part meaning to say only available through MB dealer.
File Type: pdf
Old Sep 21, 2017 | 04:35 PM
vvadim66's Avatar
W221 S550
I need to verify what is not working.
1. Key
2. EIS
3. F SAM
Old Sep 21, 2017 | 06:00 PM
'71 Pinto
OK reread original post, second key operational? No second key, remove key battery for several minutes in an attempt to reset. Still inoperable, check internal circuit board for damage if it looks fine key may need replacement
