Sponsored by: CARiD
PULLING TO left
Old Oct 4, 2017 | 01:16 PM
kipkeno25's Avatar
mercedes e220 cdi
PULLING TO left
e220 cdi 2011 70 ,000km
just had had tracking done but still pulling left
saw something about camber and castor but clueless as to whats source of problem
Old Oct 4, 2017 | 03:18 PM
belarus27's Avatar
2010 e550 p2
Uneven worn tires , failing control arms ,alignment.
Could be a few reasons , that you would have to check
Old Oct 4, 2017 | 03:55 PM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
Start with tire pressures all around, then inspect control arms like belarus said, then get an alignment.
Old Oct 4, 2017 | 06:01 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
If none of those suggestions work, you could try swapping the front tires from left to right.
Old Oct 5, 2017 | 12:38 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
For the W212 there is only Front and Rear Toe – directional adjustment OEM. We therefore manufacture front Camber and Caster, Rear Camber (and extra Toe) for all W212 models. The patented design allows precise single wrench adjustment accurately on car under load – direct on alignment rack!
Yes Toe (directional) adjustment is all that is available OEM (new car industry’s best kept secret).
CAMBER – Allows to actually “change tire contact angles” to resolve costly, premature edge tire wear, improving traction/understeer/oversteer
CASTER – Correctly resolves steering pull, increases steering response. With better turn in and high speed directional control. Along with improved anti dive/lift under brake and acceleration
Extra feature is that the front kit replaces the 4 highest wearing bushings and is 2 axis/mono ball (self aligning) without the OEM oil and air voids. Result is noticeably improved brake and steering response.
Rear kit also provides precise Camber adjustment for the first time (and extra Toe to compensate for the new Camber facility).
Also manufactured are front “replacement” top strut mounts (coil spring models) – for “Track days” Stage 2 (Street/Race) or Stage 3 (Full race) when wanting to reduce understeer – in the pursuit of hitting those corner apexes every time and going deeper into the corners with increased traction and braking response.
Another popular kit manufactured is uprated replacement bushings (12) for the ‘6’ multi link rear arms. Providing significant improvement to rear end stability, less twitch/flex, improved traction especially when applying power to lane change/overtake.
W212 incl. AMG
Front Camber and Caster kit #502916K $480
Rear Camber (and extra Toe) kit #502226 $480
Stage 2 (Street/Race) Strut adjusters Camber and Caster kit #502916-2L $545
Stage 3 (Full Race) Strut adjustersCamber and Caster kit #502916-3L $545
Rear multi link arms performance bush kit (12)#502628K $480
Delivery one kit $30 with each additional kit $20. We accept PayPal, Visa or MasterCard.
Name:  502226 Cover.jpg
Size:  15.1 KBPULLING TO left-merc-502826-k.jpg
