Solid noise issue
Does the tone of the sound change when turning in different directions (left or right) at 40+ speeds? That would be an obvious evidence it is the wheel bearing
As the car is a 4-Magic I suspect the transfer case bearing failure that seems to be an issue on many E-Class 4-Matics. When bearing fails and allows the gear wheel to move and rub with the solid part it makes whining noise and it usually does not change pitch with changing speed unless the gear teeth are rubbing too.
