Several sensor failures at once. Need advice!
2014 E350
2014 E350 with 59k on the clock. A few days ago the lane assist came up inoperative then it was stability control and now a few minutes ago abs, emergency brake light and check engine. Steering is more difficult too. What happened?? Any info is appreciated.
Received 1,736 Likes
1922 Ford Model T / no OBD
1. check for codes
2. erase them
3 start observing car voltage during driving
4. recheck if codes come back.
Car sensors don't run into family circles and they don't fail in big numbers at the same time.
More likely you had voltage drop.
At this mileage alternator brushes should be good (unless you use power excessively) but idler pulleys in last years become weak link and they can stop the belt/alternator.
2. erase them
2014 E350
I haven't checked the code yet. All this happened about an hour ago. I was thinking a voltage drop and was looking at a battery issue. Question about the 2014 e350. One battery under the hood, one in the trunk and another in the dash? Is that correct?
If you have ECO, that what the trunk battery is for. Should not affect other things.
The battery in dash was in earlier models.
Tightened up the belt and all was good.
Power voltage drop will affect electric PS.
2014 E350
To make matters worse MB can't get my car in for the next 17 days! It has to be belt, battery or alterator related. The abs and brake light went off but came back on when I used the heated seats. This time cruise control and my speedo went out too.
