Sponsored by: CARiD
Help With AMG Offsets on a E350!
Old Feb 4, 2018 | 03:26 PM
User 82321's Avatar
Hey all,
I'm upgrading the wheels on my 2012 E350 4Matic. I've got some cheap 19 inch S63 replicas on there, one cracked, so they're going to the curb.
I'm looking to put some E63/CL63 19s on the car, with 8.5, all around. I'm seeing the car came with 38mm offset wheels and that some of these are 35, 45, and all over the place.
Can anyone offer a piece of advice? I want the wheels to fit nice and flush without the need for spacers but I'm unsure what AMG-style wheels I should be shopping for.
Thanks so much!
Old Feb 4, 2018 | 04:58 PM
RA72825's Avatar
Stock ET all around for your 4M is 48, not 38. There is no 8.5” wide E63 AMG wheel that I am aware of. Fronts are 9”, but you’ll never mount them on the rear with their offsets. Have you looked around here to see what others have done with 19” wheels? The options are unlimited.
Old Feb 4, 2018 | 06:28 PM
User 82321's Avatar
Ah - sorry, I meant 48.
My car came to me, with 19 inch S63 AMG Wheels that are replicas - 8.5 front and 9.5 rear, both 245/40s with a 35mm offset - so they look fierce and pretty aggressive. I actually like the stance.
I was considering upgrading, but I'm having a hard time visualizing how anything else would look on the car. I'd like to be able to rotate the tires, but the staggered look IS pretty cool.
These are the wheels on the car now - at least I think they're S63 replicas. https://www.ebay.com/itm/19-S63-AMG-...haSv6O&vxp=mtr
Old Feb 5, 2018 | 11:06 AM
User 82321's Avatar
Bump! Anyone know if this is something I *should* stick with? Any significant performance losses from this?
Old Feb 5, 2018 | 11:15 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Like KEY said - options are unlimited.
Since you already know the size/offset that you have, you can also see how much clearance the wheels have in the fenders for potential for wider wheels.
You will find bunch of online wheel calculators that will calculate the offsets for you .
Old Feb 5, 2018 | 01:10 PM
cetialpha5's Avatar
Get whatever you like, but the only real advice on what to stick with would be factory. The cracked rim you have is already a clue. I have a set of 18 and a set of 17 inch rims on both MBs. On the 17's I've had two bent rims, on the 18, I've had one cracked and 2 bent rims. A few flats and bubbles too. Not a fan of larger tires and rims. Whatever you get, make sure you can get a spare and not just some fancy limited edition wheel where you won't be able to find one when one cracks. Even factory isn't all that great, but at least the alignment is set up correctly. Check for unusual tire wear if you don't have a stock set up. Stock was either 245/40/18 or 245/45/17 all around. So 245/40/19 is already bigger than stock, do you have any speedometer issues? I'd check your speed vs the GPS.
Old Feb 5, 2018 | 01:18 PM
User 82321's Avatar
Thanks for the input! GPS seems to be somewhat consistent. Maybe by a mile or two.
The cracked wheel I mostly attribute to the horrendous potholes over here during the winter.
I do like the stance and the look of the wheels, so I'm a bit conflicted. My handling is a bit lackluster, but I can't tell if that's the car or the wheel/tire configuration.
As a reminder, it came to (me) with replica S63 AMG wheels, 245/40/19 all around, 35mm offset (as opposed to 45mm stock) on 19x8.5s and 19.9.5s in the rear. It looks GREAT but if I have to change the tires to have the car perform better, I can do that.
Old Feb 5, 2018 | 01:26 PM
cetialpha5's Avatar
I'm not sure what you mean by perform better. All performance comes with a trade off. That's the point of engineering. You can make it perform better in one respect, but it will be worse in others. The factory set up is one set of compromises. One of them being how everyone seems to like the looks of bigger wheels and better handling, but that comes at the expense of flat tires and cracked rims.
Old Feb 5, 2018 | 02:43 PM
kajtek1's Avatar
Not mentioning the expense of fuel.
Those Hondas who ride on 155 tires and 60 psi have humongous mpg.
Old Feb 5, 2018 | 09:52 PM
User 82321's Avatar
I specified in my post earlier - my handling is terrible, so, no, the staggered set-up does really nothing aside from look good.
And as an engineer, that's the first I've heard of that!
Anyway, the car came with these wheels - it wasn't my decision. I'm looking for some safe bets and trade-offs because as it stands, I don't believe the offset and width provides any tangible benefit outside of looking good.
Thanks for the input though!
Old Feb 6, 2018 | 01:31 AM
Peachy's Avatar
2010 E550
What tires are currently on the car?
Old Feb 6, 2018 | 01:49 AM
User 82321's Avatar
245/40/19 all around on 19x8.5 front and 19x9.5 rears!
It isnt terrible per se, it’s livable. But it’s a bit of a contrast coming from my ‘14 Q50. Perhaps it simply doesn’t handle as well as I’m expexting? It’s the sport package if that makes any difference. I’m unsure if that includes a different suspension though.
Old Feb 6, 2018 | 08:00 AM
RA72825's Avatar
What BRAND of tire and spec? Michelin Sport Cup 2? Firestone road gripper? Tire makes a huge difference.
Old Feb 6, 2018 | 10:57 AM
kajtek1's Avatar
Ditto on tire difference.
I had 17" AMG wheels and hated the ride on Michelins, then put 18" wheels with super-duper tires and it was better.
Old Feb 9, 2018 | 12:43 AM
User 82321's Avatar
Hey! Sorry, I'm aware that makes a HUGE difference. I have some Mozzo Sports on it now - which from the best of my knowledge, is some off-brand Mavis-provided tire. I'm looking to slap some Continentals on there as soon as possible.
Any suggestions on best performing tire? I don't drive in the winter, as I mainly work work from home.
