Cranks but won't fire at all
2010 E350 4Matic
This week I started getting a check engine light. Was going to run code tonight. I had be noticing some unusually shifting when I slowed down the speeded up. Was thinking I was going to find a code related to the transmission but other than that the car was running fine as far as I could tell. Then tonight pulled into Costco and filled up and went to start and thought I heard a noise and the car would not start. It cranks fine but nothing. A couple of guys helped me push it into the parking lot where it sits. Trying to figure out my strategy. At my son's recommendation I will run the codes and see if it tells me anything but not very hopeful. Any advise would be welcome.
I have an 2010 E3504matic with 110K miles which has been well maintained.
2011 E550 - 4Matic, 2008 ML550
Not a 100% sure - but sounds like you need a CPS - crank position sensor - its a fairly easy swap with a hex wrench located at the back of the engine. I think its about a $30 - 120 part pending on where you get it...
Id start there - what you have is the exact symptoms...
Let us know if that's what it is?
MBNUT1 (02-09-2018)
2010 E350 4Matic
Thanks I have been doing some research and hoping you are right. Trouble is I searched this forum for P0335 code an there really weren't any other than one for a diesel. I'll start by pulling the code.
Received 1,616 Likes
2014 E550-sold 😩
I had to replace a failing CPS on my old W211 E500, but the cranking and non-start was only occasional. Have you tried starting it again? The W212 does not seem to have the same CPS fail rate. It could be a host of other issues, like fuel pump, etc
Received 4,415 Likes
'71 Pinto
MBNUT1 (02-10-2018)
Received 1,729 Likes
1922 Ford Model T / no OBD
Common behavior failing CPS is that it will fail on hot engine, but still start on cold one.
If you go back to the car now and it starts, you have your confirmation.
Still with scanners running for $10 I wonder why don't you have one in your car?
2014 E550-sold 😩
yes, this is the behavior I experienced.
I was told this car model, 2010 #550, can flood the engine in cold weather and I needed a software update. I was asking if I should replace the fuel pump just in case and they said there is absolutely nothing wrong with the pump.
They also told me that my car would have started if I held the gas pedal fully pressed when cranking it, which, of course, I did not know to do. But I do know now if it would happen again.
This may not apply to a E350 but perhaps it could...
Ferris_E550 (02-20-2018)
2010 E350 4Matic
You sound like my son. In fact he ordered one for me from Amazon prime last night. Should be here tomorrow. I will recheck the codes after I get it. So the remaining question is if it is a failing CPS why isn't there a code?
2010 E350 4Matic
I was bit disoriented because I was filling up at Costco with a ton of people in line. Fortunately a guy next to me saw my predicament an helped me push it out of the way. These are some seriously heavy cars. As he started to push he said "Maybe not" but we got it going.
It takes some guts to ask son for technical advice, but it "did happen to me" so IMHO you should get there eventually.
Coming to the situation, I am relatively new to W212, but on older models bad CPS would not trigger the code.
Than CPS is like $50 part with few minutes of labor if you know what you are doing. That would be good enough for me to give it a try, is it good for you?
2010 E350 4Matic
I was a parts replacer for many years try to avoid that now with the available diagnostics. But you are right it is cheap and easy. So if I have a repeat I will likely do that codes or not. My son said sometimes they won't through a code that the handhelds will pick up.
I have this code reader and it works great and does so much more than reading clearing codes.
2010 E350 4Matic
I have this code reader and it works great and does so much more than reading clearing codes. https://www.amazon.com/iCarsoft-Mercedes-Sprinter-Professional-Diagnostic/
Yes I think that one is very well rated
You have pretty clear code pointing to specific valve. Don't know if you experience that, but that doesn't happen very often.
So when code comes back, just find the valve on your engine. I am diesel man, so not familiar with it, but if electricity is involved - starting with pulling the plugs, washing them with good cleaner and firm plug back often does the trick.
On 2nd tough - evaporation valve should not kill the engine, so I will wait for rest of the story.
2010 E350 4Matic
https://mbworld.org/forums/glk-class...-gas-tank.html
Would appreciate it if somebody knows the part number for the evap valve and has the WIS for replacement I think that you pull the right rear inner fender liner to get at it and it sits on the charcoal canister.
'71 Pinto
Charcoal filter shutoff valve current part # is 0014701393.
MBNUT1 (02-12-2018)
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
Not sure if this helps any but I've been getting that same P2422 code. Which in my case throws a CEL for a day or two and it goes away for a day or two and so on. I've noticed whenever, I'm low on gas and I fill up, the car will rough idle and even a few times shut off. Once it shuts off I have to crank it 5-10x to get it to turn back on. Also if I turn off the car on my own and try to crank it back on after I'm done with the fillup the same thing....It'll need 5-10 cranks to turn back on. This issue only started alongside the P2422 code. I'm in the process of fixing some other more pressing items but I decided today to go ahead and order part # 000-470-88-93 Purge Solenoid in hopes that this will fix the issue and if not I'll move along to the canister etc.
MBNUT1 (02-12-2018)
2010 E350 4Matic
I also read a post about a guy cleaning the shut-off valve and canister on his S class which fixed a filling problem he was having so I am wondering if the purge valve can be cleaned as well.
2010 E350 4Matic
Quick update. My CEL went out on its own and the car is back to driving normally again. What a nice car it is when I'm not worrying about it. Haven't tried to fill it up again yet.
