Sponsored by: CARiD
question about open windows feature
Old Feb 10, 2018 | 03:12 PM
#bestornothing's Avatar
W212
Question question about open windows feature
Hello! i have a question about W212. Does Every W212 have the "hold open door key for opening all of the windows and sunroof"?
""in 2011 models only""
Old Feb 10, 2018 | 03:35 PM
konigstiger's Avatar
'71 Pinto
MBUSA, yes.
Old Feb 10, 2018 | 03:36 PM
baybombers's Avatar
2020 CLS 450
I believe all the FL models do. Not sure on pre-face lift.
Old Feb 10, 2018 | 03:58 PM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
My 2010 does it, but it is not real useful since you have to be about 3 feet from the door handle to do it. By then I could just as easily get in the car and open all four windows. Personally I don't like the sunroof opening as well as the windows.
Old Feb 10, 2018 | 04:31 PM
W212
is there any video doing how to do it ?
I try but it does not open
Old Feb 10, 2018 | 04:39 PM
Arrie's Avatar
Just point the key at the infrared sensor on the driver's door handle and hold the unlock button. It will first unlock and then all four door windows roll down. If your sunroof blind was closed it also rolls open at this point but to get the sunroof itself open you will need to hold the key again.
If the sunroof blind is open when you do this the sunroof opens with the door windows.
You can also close the windows the same way using the lock button on the key.
At least this is how it works in my 2010 model car.
Old Feb 10, 2018 | 07:18 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I found the feature too erraticall.
We need windows open for our dogs, but even the single push button sounds exiting - the way it works without good control makes it unusable.
