Anyone interested in a set of oem amg wheels? I believe they are 18x8.5 et48. Two wheels are in pretty good shape, the other two appears to have some clear coat issues, could use a recon. All tires are still pretty new. Over 9/32 remaining each. One tire has recently developed a bubble though..
Hello, Dibs maybe?
I'm interested in these.
1. Should I worry about the bubble? Should I replace all tires at once or just that one? I have 4Matic.
2. Will these fit my 2014 E350?
3. I'm from 28262, Charlotte, NC; can someone please help me the estimated shipping cost.
Thanks.
I have the same wheel and they will bolt right up with no issues. As far as the tire condition is concerned, I cannot comment. Shipping is all over the board depending on the shipper. Should be less than $200.
Shipping fees change quite often, but in the past I had good quote from USPS and they don't require the wheel to be packed. Just put the label inside the wheel.
Sometimes putting 2 wheels together as single package saves some money.
There used to be some sticky in the classified wheels section where it mentions the lowest price to ship and that beats UPS/USPS. Anyway, a tire with a bubble is basically trashed. Means a belt inside is broken and you no longer have the structural integrity when it was new. I wouldn't drive around with any tire with a bubble.
so, Can I replace that one tire only or all 4 (since 4Matic). I mean, as long as same tread style (tyre style) matching tyre or all of them?
Thanks.
With 9/32's, that's practically new. Usually most tires are about 10/32's new. You should be fine with getting just one new tire. Just get the same tire with the same tread pattern.
You're going to be fine replacing just the one tire, all the others are practically new. PM me an offer if interested. I can provide more detailed pictures if you like.
I had Benz wheels shipped by greyhound a few years ago..seller had used them before and said it was very reasonable. Greyhound called and I went to the bus station to pick them up...ya it was weird...lol
I had MB door shipped by Greyhound.
For big items it might be good option, but check how far the buyer has to drive to pick it up.
I had wagon at the time and with all that packing, loading it was not very easy.
Bare in mind that it is not easy to fit 4 big wheels in sedan, especially when you care about leather finish.
