Sponsored by: CARiD
Error code P0128
Old Feb 15, 2018 | 04:50 PM
Fabi139's Avatar
E350 4matic
Error code P0128
I’ve had my check engine light for about 2 weeks now and diagnosed error code p0128. I installed a new thermostat and last night and still have the check engine light on. I drove it more than 30 miles already but doesn’t seem to go away. I tryed erasing the code but only comes back right away. My temperature shows 147 degrees Fahrenheit meaning it’s very low. I soon need to go for an emissions test but won’t pass with this problem. What should I do?
Old Feb 15, 2018 | 07:21 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
I haven't dealt with this error code on a Mercedes yet, but in my Chevy Truck the problems lies with the ECT (Engine Coolant Temp Sensor) or the attached wiring.
Old Feb 15, 2018 | 07:47 PM
RA72825's Avatar
How are you measuring the temp in Fahrenheit? The dash gauge is in Celsius. In any event I don’t believe your new thermostat is working properly. Was it an OEM part? They are not cheap. Your temperature is so low reflecting an open thermostat condition (failure). Your CEL will not go away until this is fixed. Once again, I think your new thermostat is bad.
Old Feb 15, 2018 | 09:57 PM
cetialpha5's Avatar
Yeah, try it again. I believe Wahler is the OEM maker of it. I've replaced mine and the new one was fine. It was around $70 on Amazon.
Old Feb 15, 2018 | 10:04 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Was it a thermostat or electro-valve?
Code not allowing clearing would indicate the 2nd.
Old Feb 16, 2018 | 01:49 AM
2016 E350 Sport 2WD
Go to Youtube and look for a video by South Main Auto Repair with title 'My Red Hondoo has a P0128 (and it's not the thermostat)'. Scan data shows car was warming up and all of a suddden the CTS dropped the temp reading drastically (temp didn't really drop as indicated by the CTS).
Old Feb 16, 2018 | 12:54 PM
Fabi139's Avatar
E350 4matic
My OBD scanner gave me the reading in Fahrenheit. Converting it into celsius is about 67 degrees Celsius. It should be working properly since I did purchase OEM from the Fcpeuro.com
I don’t understand how it is low on my gauge it shows 95 degrees celsius for the coolant temperature.
Old Feb 16, 2018 | 04:41 PM
kajtek1's Avatar
I had several scanners with live data giving me false reading. TorquePro is telling me my exhaust DPF is reaching 1300 psi occasionally.
I would confirm it with infra red to start.
And again, if you have electrovalve, it is computer that tells it when to open.
Old Mar 12, 2018 | 02:45 PM
jroach's Avatar
2010 GLK
Fabi139,
Not certain if you still have the code but I had a similar issue (it did go away eventually). I believe it is tied to the emission group so it's a bit stubborn. Here was my experience:
https://mbworld.org/forums/glk-class...orn-p0128.html
Old Dec 15, 2023 | 07:18 AM
porrte's Avatar
c180
My c180 gives this error nearly every month, i googled the p0128 code and it says about cat. converter, but my service man says that it can cause o2 sensor, so i changed the sensors but it still continues.. I think this is chronical problem of my car
Old Dec 15, 2023 | 09:54 AM
Cosworth2000's Avatar
2022 E53 AMG
I have this same error and tried to change my own thermostat however it is a very involved task since on my engine you also have to remove the wiring harness. So my car is going to MB to change out the thermostat and pay to have this done as this one is over my head.
Anyways, you may have an issue related to the amount of coolant in the system and the only way to hack it is to do the following. Your system is "under" pressured and since there maybe air in the system, it's not allow the temperature to rise. One way to help with this is to fill the coolant without placing the full cap on the system and wait for the bubbles to emerge. This is dangerous but of course less if you already used a coolant machine which MB uses to charge up the coolant system.
Old Dec 15, 2023 | 10:19 AM
cetialpha5's Avatar
Try a different service guy. If you google P0128, you get a coolant error, not a cat error so either you remembered the wrong code or your googling is bad. Normally you would change out the thermostat for this problem.
