Sponsored by: CARiD
Blind Spot Assist and Adaptive Main Beam Assist both inoperative?
Old Mar 10, 2018 | 08:12 AM
Shaney75's Avatar
E200 CDi
Merecedes E200 CDi 2012
My Blind Spot starting playing up and then totally became inoperative. Now the Adaptive Main Beam is in operative. Any suggestions?
Old Mar 10, 2018 | 08:20 AM
RA72825's Avatar
Yes. Check your battery state of charge.
Old Mar 10, 2018 | 09:12 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Aux. battery could be going bad.
Old Mar 10, 2018 | 09:49 AM
Shaney75's Avatar
E200 CDi
Thank you for your replies. I will check the auxiliary battery as suggested. Does the blind spot and adaptive main beam work solely off this battery?
Old Mar 10, 2018 | 10:46 AM
RA72825's Avatar
Check both batteries. If your ECO function is not working, it will be the smaller battery in the trunk. You may need to replace both if they are weak. These cars need strong battery state of charge to operate all functions, or features will go into suspension mode.
Old Mar 10, 2018 | 11:49 AM
Shaney75's Avatar
E200 CDi
Spoke briefly to MB dealership, they think it could be the camera in the front windscreen causing the issue but I’m not too sure about that. Any comments would be appreciated. Thank you in advance.
Old Mar 10, 2018 | 12:44 PM
RA72825's Avatar
The camera in your windshield is for the lane keeping assist and auto high beam. Your distronic sensor is the star in your front grill, while your blind spot sensors are buried behind your rear fenders. I think whoever you spoke with has no clue what manufacturer they work for. Lol. Start with the easiest solution always; batteries.
Old Mar 10, 2018 | 12:56 PM
Shaney75's Avatar
E200 CDi
Many thanks KEY08, your advice is very much appreciated.
Old Mar 10, 2018 | 12:59 PM
Shaney75's Avatar
E200 CDi
Had my main battery checked, when engine is running its achieving 14.6 volts. It came up on the tester as “GOOD - NEEDS CHARGING”. Started off around 10.5 volts but went up to 14.6. Not sure what the auxiliary battery should read.
Old Mar 10, 2018 | 01:33 PM
RA72825's Avatar
10.6 is a dead battery. 12.6v is a full charged battery. 14.6v is fine while charging, but that just means your alternator is functioning properly. You could load test the battery, but I can already tell your battery is toast and is the cause of your problems. Look at this battery state of charge chart. At 12.2v your battery is only at 60%.
Old Mar 10, 2018 | 02:48 PM
Shaney75's Avatar
E200 CDi
Thank you for the information it’s greatly appreciated. Just checked car’s main battery again and measuring 11.9volts, which I can see by your chart that this is well below where it needs to be. Do you think the auxiliary battery will be ok?
Old Mar 10, 2018 | 02:51 PM
If the main battery is original to the car then it needs to be replaced and the same goes for the aux. battery. This past year I had to replace both on my 2011 E63. If you leave a malfunctioning battery in a car it can damage other electrical equipment..
Old Mar 10, 2018 | 02:58 PM
Shaney75's Avatar
E200 CDi
Many thanks for that. Is changing both the auxiliary battery and the main battery something you can do yourself? Or do you need to reset using diagnostic equipment?
Old Mar 10, 2018 | 03:49 PM
RA72825's Avatar
Yes, you can replace yourself. You may need to reset your clock or possibly your window/sunroof. The hardest part is lifting the main battery into place as they are heavy.
Old Mar 26, 2018 | 09:54 AM
LisaMichael's Avatar
E350 Sedan 4 -matic
Same thing has happened to our 2012 e-350. Can you post if the replacement of the auxiliary battery worked?
Old Jun 7, 2020 | 02:02 PM
07CL550Benz's Avatar
2007 CL550
I had a similar issue with my S600 when I bought it. And yeah scanning it is the first step. My issue ended up that it needed to be calibrated (which I was able to do at home by printout out a piece of paper) and then the real issue was corrosion in the headlamp switch. But you could also have a faulty cable, there are 2 cables, one to the camera and one from the module to the instrument cluster. The cable can bend a lot, especially up by the camera and that can obviously cause issues.
