Sponsored by: CARiD
w212 facelift grill removal
Old Jun 30, 2021 | 11:38 AM
konigstiger's Avatar
'71 Pinto
Originally Posted by meljayger
From the image you have attached, it seems the facelift W212 come in two different type of bumpers and two types of grill?
VIN?
Old Jun 30, 2021 | 11:49 AM
Fliplegend's Avatar
S212 E350 Estate
Yes, there is a luxury and a sport version of facelift W212's.
Old Jun 30, 2021 | 11:50 AM
meljayger's Avatar
GlC
The VIN number is WDD2120342B083260. Thank you @konigstiger
Old Jun 30, 2021 | 11:58 AM
meljayger's Avatar
GlC
This is my W212. The diamond grill is a aftermarket replacement.
I want to achieve this look.
I believe there are 2 types of bumper for W212. Pink is mine and the blue is the Executive (Elegance) Line.
2 types of grills for the 2 different bumpers..
Old Jun 30, 2021 | 12:01 PM
'71 Pinto
Not certain about your aftermarket grille attached original factory info, conversion bumper & grille parts for 2015 212.234 wagon same for 212.034 sedan, and disassembly/assembly instructions. To be clear Parts Information = current factory parts; Bumper = replacement parts for 2015 model year conversion, Grille = replacement parts for 2015 model year conversion. Note grille pattern differs from your photo.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 30, 2021 | 12:07 PM
meljayger's Avatar
GlC
Sorry, I am poor in this. Which PDF you are referring to when you mentioned Line 14?
Can you confirm that this model has different bumpers for Avantgarde and Executive Lines respectively?
  #32
Fliplegend's Avatar
S212 E350 Estate
Looks like you will need the chrome shroud that goes around the whole grill along with the grill and hood ornament to achieve that look. As always, konigstiger's got you covered.
Old Jun 30, 2021 | 12:14 PM
  #33
meljayger's Avatar
GlC
Your W212 has the same bumper and the grill as my car (until I changed to the diamond grill).
This bumper is different to that of the Executive Line which has a bigger chrome grill.
I just need to confirm that I have to change my bumper in order to achieve the Executive Line classic look.
Old Jun 30, 2021 | 12:17 PM
  #34
Fliplegend's Avatar
S212 E350 Estate
No it does not. Look harder. They are real close but not the same.
Old Jun 30, 2021 | 12:22 PM
  #35
'71 Pinto
Disregard thought you wanted to remove grille. Revised my post see bumper & grille attachments to convert.
Old Jun 30, 2021 | 12:29 PM
  #36
meljayger's Avatar
GlC
Not certain about your aftermarket grille but attached factory info,see line 14 in attachment. Attached conversion bumper & grille parts (2015 212.234 wagon) same for 212.034 sedan.
So can you confirm that I will need to get new bumper for the Luxury grill?
If this is correct, is it complicated to do so? I do not get much help from my local MD agent. Thank you.
Old Jun 30, 2021 | 12:38 PM
  #37
meljayger's Avatar
GlC
Not certain about your aftermarket grille attached original factory info, conversion bumper & grille parts for your model year (2015 212.234 wagon) same for 212.034 sedan, and disassembly/assembly instructions.
This document mentioned 2 different types of grille for Avantgarde (mine) and Elegance Line. Does this mean I have to get a new bumper in order to have the Elegance/ Classic grille?
Old Jun 30, 2021 | 12:42 PM
  #38
meljayger's Avatar
GlC
@konigstiger May I know are you working for MB or a MB parts company? Amazed with all the info you are able to share (Thank you!)
Besides this Avantgarde to Elegance bumper conversion that I want to do, I am looking for help on inability to connect my iPhone to my media player (NTG 4.5) via cable.
  #39
'71 Pinto
Old Jun 30, 2021 | 12:48 PM
  #40
meljayger's Avatar
GlC
Thank you sir for your help. Will try to digest all the info you have shared.
Old Jun 30, 2021 | 12:56 PM
  #41
'71 Pinto
Try 0008271200.
Old Jul 1, 2021 | 02:25 AM
  #42
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
US "Luxury" vs "Sport" front ends, from the 2016 brochure. The "Elegance" vs "Avantgarde" actually refers to interior color combinations, but those are bundled with the traditional vs AMG exterior trim, and the comfort (17" wheel) vs sport suspension (18" wheel), at least in the US market.
Old Jul 30, 2021 | 03:32 PM
  #43
1965 Beto's Avatar
None
So, in order to change grills from classic to sport the bumper needs to be replace too? How about just the inner mesh on the classic? Can that be removed?
Old Jul 30, 2021 | 04:18 PM
  #44
Well if you had both grills side by side, they are as far as I know one piece with the surrounding bezel, you undoubtedly could trim the sport interior piece and cut out the luxury piece and somehow get them to fit together, with enough fabrication, almost anything as possible. My friends and I used to call that kit bashing, Leftover from when we were teens and we'd take parts of different plastic models and build our own creations.
Note that the bezel on the luxury trim is chromed plastic, while the bezel on the sport trim is body painted. I believe the lines are subtly different around the outside of the bezel that's why you can't just drop them in and need the sport bumper to go with a sport trim. Of course with the luxury cars comfort suspension ride, the AMG body trim might look a little funny riding an inch and a half higher off the ground. I would leave well enough alone.
Old Jul 30, 2021 | 08:01 PM
  #45
Hi @konigstiger I hope you can help me
See my pic in this thread of the luxury/comfort package front and sport/AMG front this is specific for model year 2014-2016, aka facelift. Afaik, only 6 cyl models had the lux option in the USA.
Old Aug 6, 2021 | 04:53 AM
  #46
N7legion's Avatar
2014 W212 E350
Replacing the grille is a pain.
Someone backed up into my car and cracked the grill. Had to replace. The bumper needs to come off. The chrome grille surround needs to come off to expose more hidden rivets. You can drill them out but I opted not to and simply cut them off with wire cutters. I figured less possible damage
This video shows the process to do the entire removal. You will need a rivet tool. Also make sure you lay the bumper on something that won't scratch the paint. I'm sure OP got this resolved already but hopefully someone else will benefit.
Old May 24, 2022 | 04:54 AM
  #47
meljayger's Avatar
GlC
VIN?
WDD2120342B0832600 thanks!
Old May 24, 2022 | 04:55 AM
  #48
meljayger's Avatar
GlC
Try 0008271200.
This works! Thank you for your help!
Old May 24, 2022 | 05:01 AM
  #49
meljayger's Avatar
GlC
Mine is Sport styling currently and still is looking to change to the Luxury styling with no luck.
Old May 24, 2022 | 05:42 AM
  #50
yeah, thats a tall order.
US luxury vs sports from what all I gathered and remember....
  • different bumpers front and rear, different grills and the rest of the front and rear trims.
  • different suspension (Comfort vs Sport suspension)
  • different dash and door trim (warm tone Elegance vs cold tone Avant Garde)
  • different steering wheels (round vs flat bottom)
  • different exhaust ends (fully hidden tips vs dual tips sticking through the rear bumper skirt)
  • 17" vs 18" wheels
