Steering Wander
I hit a rather large pothole about 3 months ago and I have bee fighting this issue ever since. The steering feels like the car wants to wander a little and follow road imperfections. I had a 4 wheel alignment performed and it was a little better. I put new struts on front. I rotated the front tires right to left. I replaced the rear tires (no issues, they were just due). The car drives OK, just not the way it did originally. It's driving me crazy because I know how it used to feel.
I have rear shocks on order to replace but I only expect the ride to improve from that upgrade. I've looked at the front suspension and wheels and I don't see anything obvious. I've got no vibration or pull which makes me think the tires are probably OK.
Any words of wisdom out there? I'll probably end up having to take it to a Mercedes front end specialist or it will drive me crazy.
My other car is a C7 Corvette and my wife drives an Audi Q7, every time I drive one of those I'm reminded it ain't right.
although might be a bent wheel , but it would cause a vibration
Than I ditto on checking mentioned control arm bushing. On my 4 years old MB the bushing has big cracks on it and even my car drives straight, I will have to replace it soon. (whole arm as bushings on lower are not replaceable)
Mind my MB has 180k miles, but those bushing on older cars lasted for 30 year and 1/2 million miles.
Who did the alignment?
You said you don't see anything obvious so it could easily be the toe. With wrong toe the weight shift of the car will change the steering where the car will want to go.
If toe is wrong you should see it on the tires after enough miles.
