w212 stuck in park
I bought that W212 E350 but in the past month the car has twice been stuck in park.
The shifter is up by the steering wheel so I do not know where the release is.
The first time I went to work with my dad's toyota and when I got home in had no problems. The second time is right now I had to go out
but the shifter will not leave Park. I read about break light switches and such but there seem to be non of the symptoms.
Could you please give me some advise and also tell me if there is an emergency release on the shifters that are by the steering wheel?
In case I go to wash it or something and can't leave
http://www.fluidmotorunion.com/merce...stuck-in-park/
from all the posts i find inside and outside of mbworld, seems good power is needed, so if you have a jumpstart device you could try that, but i would be checking your battery and charging system to make sure your fully charged...
Low voltage is the issue. Some components are more tolerant of lower voltages some are not.
