Sponsored by: CARiD
Just noticed this today
Old Apr 11, 2018 | 03:19 PM
Zavato's Avatar
2012 E350
So I noticed this- center armrest’s material covering- vinyl or MB Tex, is slightly bubbled - this affects less than a 2” diameter. Anyone ever experience that? As this is cosmetic I would imagine my CPO warranty would not cover this. If anyone has experienced this, I would like to hear how you addressed it.
Old Apr 11, 2018 | 03:26 PM
RA72825's Avatar
Have not experienced this. Maybe you can heat that area up with a cloth and iron and re-energize the glue? Poke a glue hypo in through the side to get some adhesive in there? Maybe there is an upholstery guru on here with some ideas for you, short of replacing the door itself.
Old Apr 11, 2018 | 03:28 PM
belarus27's Avatar
2010 e550 p2
There is a topic about it....
and i think what helped even me (temporary tho) is a heat gun.. heat it up and stick back together.
the whole piece is kinda expensive if you were just gonna replace it.
Old Apr 11, 2018 | 03:52 PM
Zavato's Avatar
2012 E350
found the other thread- I’ll try a heat gun over the weekend
Old Apr 11, 2018 | 03:53 PM
Zavato's Avatar
2012 E350
I thought of trying to get some glue in there -
Old Apr 11, 2018 | 04:45 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
OP, just following the shadow line in the photo, is it happening on the other side as well?
Old Apr 11, 2018 | 05:37 PM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
That happened on mine a few months ago and was covered under ELW. They did ask to look at the general interior condition which was fine with me.
Old Apr 11, 2018 | 06:06 PM
dbldpr's Avatar
Veteran: Navy
If you know someone that takes insulin with a needle you can ask them if you could have one needle. If you get one you can inject glue into the area that has risen. Then you can heat the area up and press it down. The added glue should hold it down. Try and make the puncture in an area that you do not see. I use this method to re-glue wallpaper.
Old Apr 11, 2018 | 10:32 PM
belarus27's Avatar
2010 e550 p2
good idea , combine glue and heat gun , im sure it'll stay there
Old Apr 12, 2018 | 07:00 PM
TrouT21's Avatar
E350 Sedan
I have it on both sides of my armrest
I will be watching this to see any advice. It has been bothering me for months...
