Adjusting intelligent LED light system
My question is, since these are electronically controlled mechanical lights I assume they are also self-adjustable; however, is it possible to somehow tweak them such that the dim patch can be resolved? It feels as if it's a small matter of moving part of the multibeams on the right-hand side a bit to the left. I don't think the bulbs need replacing but I'm willing to consider they might -- how could I test this? The light output in high beam mode is flawless though.
On a slightly unrelated note, the lights can be configured for right or left-hand side drive. What should I pick if the steering wheel is on the left? I went with right-hand side drive since I assumed it refers to the side one faces incoming traffic. Changing this setting does not affect the dim patch in the slightest.
Is the dark spot that can be seen in the picture normal? I would have thought that the beam on the right-hand side would extend further out than the one on the left. What do you think?
edit:
or you can try this. Idk if it will work.
https://mbworld.org/forums/e-class-c...djustment.html
