Sponsored by: CARiD
Airmatic Troubleshooting Codes:C151E1C & C155664
Old Apr 24, 2018 | 01:31 PM
WV E63 AMG's Avatar
2010 E63 AMG
Hello all, I know the C155664 code has been discussed before but I didn't find anything for C151E1C. The C155664 code was stored in the system but the C151E1C code is current and stored.
When I start the car I get a "Malfunction" message with an arrow pointing up inside a car silhouette. I can hit "OK" and it goes away. The suspension button on the center console does nothing. Nothing sags when it sits over night (at least not that I can notice), and I can hear a very small amount of air being released after I park the car.
Can anyone give me a place to start? I checked the fuse (7.5 amp? seems small) but haven't replaced the relay yet.
When scanning the car I get:
C151E1C (stored&current) "left front level sensor has a malfunction. The voltage value is outside the permissible range"
C155664 (stored) "The Compressed air sensor for the system pressure has a malfunction. There is an implausible signal"
2010 E63 AMG
Thanks in advanced and sorry if I posted in the wrong spot.
Old Apr 24, 2018 | 06:11 PM
konigstiger's Avatar
'71 Pinto
This may help...
File Type: pdf
Old Apr 25, 2018 | 11:16 AM
WV E63 AMG's Avatar
2010 E63 AMG
This may help...
Thanks!
I had read that before but it doesn't mention the other code. Also, the Compressor code isnt current, its only stored.
I changed the oil last night and while it was warming up I noticed the car would let our air, then the compressor would run. this happened every couple of minutes.
I want to disable the system until I figure the issue out (that way I dont burn out the comp), how would you guys recommend I do this? pull the fuse?
Old Apr 26, 2018 | 03:33 PM
WV E63 AMG's Avatar
2010 E63 AMG
Originally Posted by WV E63 AMG
Thanks!
Did some more research and you cant just disable the system.
https://mbworld.org/forums/w212-amg/...lfunction.html
^ I started a new thread to resolve these issues.
When I fix it Ill be sure to post something about it.
