Need Help - Headlight Level Sensor, Airmatic Malfunction
Hey guys/gals. Sorry I have been posting a good bit to the forums lately abut this topic but I'm really struggling to figure this out, as my local MB shop has been worthless. I have searched but found nothing regarding headlight / suspension level sensor malfunctions. There is a part (006 542 83 18), that monitors the height of the vehicle, mine is not sending any mV back to the ECU, so it is giving an error.
I need three answers:
1: Could this malfunction be why my airmatic is not working?, There is no air suspension in the front so I wouldn't think so, but no other suspension related codes are active.
2: How can I troubleshoot the sensor, IE how do I know if voltage is coming into/leaving the sensor?
3: If there is no voltage coming into the sensor, how can I track the wire back to the next connection, to see if there is a break there.
My plan of attack,
Take the passenger side sensor off and put it on the driver side to see if any voltage is leaving the unit (I can test this with an OBD2 reader)
If that fixes the issue, try and find a replacement. There are some being sold over seas (used) on Ebay. But I wish I knew if other models' sensors where compatible for the W212.
If no voltage is coming into the sensor, I'll start tearing into the engine compartment looking to see where the wire leads. (on a separate note, my right turn signal is going in and out?, maybe I have a wiring problem affecting multiple systems?)
Hate that i really have no valuable information to provide, but i wish you the best of luck. Weird problem you have there.
On my '10 e63, my airmatic malfunction message ended up being a split in the main air line running from the compressor to the valve block. Replaced that line and the two fittings, all is back to normal.
"1: Could this malfunction be why my airmatic is not working?, There is no air suspension in the front so I wouldn't think so, but no other suspension related codes are active."
Yes.
"2: How can I troubleshoot the sensor, IE how do I know if voltage is coming into/leaving the sensor?"
Connect to STAR. It will tell you if it is an open or shorted wire or faulty sensor. You can monitor sensor actual values; you should see the voltage change by bouncing the bumper up and down.
"3: If there is no voltage coming into the sensor, how can I track the wire back to the next connection, to see if there is a break there."
Use WIS to study the schematic and to locate connector and ground locations.
Alright, so I took the passenger side sensor off and plugged it into the driver side terminal, BOOM its sending voltage. So I purchased a new sensor straight from Germany, I will update you all when it gets installed. (will arrive late May )
Thanks dinman and bbirdwell for the responses and well wishes.
Got the sensor used from Germany, put it on and problem solved. No more Malfunction warning and the Suspension button works.
For those that might have this problem, don't be fooled when it part is described as "headlight level sensor", although it might adjust the headlight it also controls the suspension.
Cheers-
Glad it's solved for you! Curious how much the sensor was?
Cheers-
Thank you so much this tread has saved me , having similar issue with 2016 E63s whereas the rear airbags doesn’t inflate at all , tested relay circuit installed new bags and pump and tried calibrating vehicle with icarsoft only to see error message only to see sensor values out of specified range.
Voltages on sensor ranges 1.5v with sag on right rear side and 3.6v with sag on left rear side. Based on raising car height with jack I’ve realized that when raising the car voltages would increase from 1.5v at bottom out low upwards to tell control the tire height
prior to this car would sit lower on driver rear side than of passenger rear side also the suspension button is stuck on one LED and cannot change. I’ve ordered new headlight sensor for left rear , I’ll update this post and let you all know if the Airmatic comes back here are the pics of unbalanced rear end.
I’ve read through the e63s w212 service manual and the Airmatic control has a lockout feature that it knows when the car is on jack to prevent Airmatic operation if the sensor is reading that tire is high or voltage is at 3.6v and other is 1.5 v in bottom Sag position it’s gonna think car is on jack and refuse to calibrate one can also assume suspension will not adjust
