Sponsored by: CARiD
Backup Camera Not Available
Old May 2, 2018 | 02:45 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
There are times when I get a message that the backup camera is not available. Doesn't seem to follow any particular pattern that I can discern, and it becomes available as suddenly as not available. Any solutions??
Old May 2, 2018 | 03:11 PM
belarus27's Avatar
2010 e550 p2
might be a bad contact
there is a thread here about it
Old May 2, 2018 | 04:07 PM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
^^ this as first check.
I had the same thing last year. I got back there and disconnected the connector at camera harness, added a bit of dielectric grease and reconnected. No issues since. IMO the connect/disconnect process helps clean the contacts, the grease maybe helps reduce future oxidation.
Old May 4, 2018 | 09:33 PM
2016 E350 Sport 2WD
Is the connector located very near the camera or more forward, near the chassis wiring harness, the other end of the camera harness?
Old May 6, 2018 | 09:42 AM
raja777m's Avatar
2014 E350 4M Diamond Silver
Whole 360 camera setup not working:
Please help.
Old May 6, 2018 | 01:07 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
I recall that it is located inside the trunk lid lining. There is another thread about locating and checking the connector.
https://mbworld.org/forums/e-class-w...ar-camera.html
Please help.
Have you tried rebooting comand by holding in power button until screen/unit cut out? Those reboots help if comand gets buggy.
Old May 7, 2018 | 08:21 AM
raja777m's Avatar
For a whole day it didn't show up, as I was restarting the car many times I didn't felt the need of restarting the COMAND.
Anyway, my car is like super man and the evil eye is the kryptonite.
I left it under the sun and things started working again.
Old May 7, 2018 | 09:46 AM
thefisch's Avatar
Top Answer: 1
Glad to hear it is working again. It seems to me at least that comand goes into suspend/sleep mode when the car is turned off but it still uses some power. Whereas the hard reset of comand cuts full power to comand and it goes through a full reboot which helps with some bugs.
Old May 7, 2018 | 09:18 PM
2016 E350 Sport 2WD
Thanks for that link. I believe the problem I sometimes have is somewhat different than the camera just doesn't work. I get a message on the screen that says something to the effect that the rearview camera view is not available. This may be a small difference, but the screen comes up, and the message is displayed. I will be looking at the connections and wiring as soon as my DeOxit arrives. I drove from AZ to KS a couple of weeks ago and the camera was not available, but as soon as I decided to create a post and look for the exact specific message, the camera has worked correctly every time.
Old May 22, 2018 | 12:12 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
