Sponsored by: CARiD
2012 E350 - Engine idle sound is not like my previous E350
Old Jun 6, 2018 | 08:03 PM
coupedncal's Avatar
I recently picked up a 2012 E350. Car rides really well but i have noticed the engine idle sound is not smooth like the previous series E class. I had a 2006 350 and it idled such a way that you barely heard the engine. Here, the engine sound is pronounced. Is this due to direct injection? And is this normal?
Old Jun 6, 2018 | 08:58 PM
MBNUT1's Avatar
2010 E350 4Matic
The noise is likely due to the direct injection. I have the old engine but my sister's car has the new. You can definitely hear the direct injection on her car. I much prefer her car by the way. Assuming that it is the injectors it is normal.
Old Jun 7, 2018 | 11:33 AM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
If the noises you hear is a clicking noise or a diesel like noise than that's normal and caused by the direct injectors.
Old Jun 7, 2018 | 12:07 PM
Kilt's Avatar
2013 E350
The first time I heard the direct inject 302 V6 -- tick, tick, tick . . . or tap, tap, tap -- I asked the dealer if this was normal. I thought the used vehicle might have bad valves or something. But, no, that is the normal sound, and I eventually bought a 2013 E350 with that engine. I don't hear the sound in the car, and I like the engine a lot so far. More than enough power and good enough gas mileage for me.
Old Jun 7, 2018 | 09:02 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Your old car had the M272 engine...... completely different than your new M276 engine which is a bit noisier due to the direct fuel injection system. Now the M276 engines do have an issue with noisy high pressure pumps. It's not common but it does happen.
