Sponsored by: CARiD
2012 E350 No Start-All accessory electronics good
Old Jun 11, 2018 | 02:11 PM
Jerhra11's Avatar
2020 A220,2014 E350, 2016 E450 Cabriolet, 2021 E450 Coupe, 1999 Porsche 911 996 Carrera
I purchased a 2012 Mercedes E350. The battery is OK (checked), I replaced the starter relay, all fuses are OK. I have a iCarsoft OBD II tester. I have 2 DTC codes under CWG[ZWG] CENTRAL GATEWAY
U10388 Diagnostic CAN communication has a malfunction. Bus off.
U11600 A Bus keepawake unit was detected.
I need help interpreting the codes and correcting
All electronics in the car work. It was a flood damage car. Under the carpet looks fine.
Thanks for any help,
Jerry
Old Dec 25, 2021 | 07:35 PM
Geiroh's Avatar
w212
Solution ?
Old Dec 26, 2021 | 05:15 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Have you checked....:
- "solderless pins" in your Electronic Ignition Switch (EIS)
-or Brake switch?
-or Neutral Switch?
​​​​​- any particular DTC involved?
Old Dec 27, 2021 | 02:16 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
Originally Posted by Geiroh
Solution ?
you also have a flood damaged car with just those two codes and no others?
