Sponsored by: CARiD
Tpms hijinks..
Old Jul 3, 2018 | 12:19 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Tpms hijinks..
So about 60 days or so after I install my expensive new wheels LR tpms says 28 or so. Others are accurate. Been working like a champ til then. Then it goes to 23 and hangs around. Figure tmps is dying. Replace. Reset. Same problem exists. Aggravating. Sone experienced this?
Thanks if you have info..
Old Jul 3, 2018 | 12:37 PM
RA72825's Avatar
Not sure what LR tpms means. So, you replaced the bad tpms and it is still not reading the pressure accurately? The signal pickup for whichever sensor this is associated with may be bad.
Old Jul 3, 2018 | 01:51 PM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
I'm thinking left rear .
Old Jul 3, 2018 | 05:10 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
What does the pressure read with your own gauge?
Old Jul 4, 2018 | 10:38 AM
konigstiger's Avatar
'71 Pinto
Assuming correct replacement was used (cross reference 0009057200 433MHz), correct install, and correct pressure confirmed at tire, next place to look is CU see attachment.
Old Jul 5, 2018 | 11:02 AM
aquinob's Avatar
2010 E350, Sold 1998 C230
So I'm guessing that you moved the tpms sensors from the old wheels to the new ones? How old were the old sensors? If they are over 6 years the batteries may be starting to go. The only way to get new batteries is to replace the sensors. I just had 4 new tires put on a set of 17" take offs that I had bought almost 3 years ago and I got 4 sensors off Amazon for about 30 something each that were described as OEM compatible. Dealer mounted the rubber on the new rims and the new sensors worked just fine without any special programming or issues. Batteries in the sensors can last up to 10 years, so you can take your chances that they will last long enough to get through a set of tires. It's also possible that the installer damaged one of the sensors putting them on the new rims.
Old Jul 6, 2018 | 08:08 PM
bigjule's Avatar
2007 mercedes e63, 2006 bmw 530 Xi with Mtech kit , 2005 ford expedition
Do u have info on the tpms you purcshpur from Amazon ? I need a extra set for my oem winter set up
