Sponsored by: CARiD
Keyless Go Push Button Start Problems
Old Sep 26, 2019 | 07:43 AM
Hoover2112's Avatar
2014 W222 S Class SE 350d
Originally Posted by stevil555
I changed the battery in both fobs and there was no change in the behavior.
Thanks for all of the ideas. I guess to the dealer I must go.
Hi - did you ever resolve this? My S Class has the same issue. Button generally wont start in a morning (more-so when damp). Key never fails and as soon as I get to work i can put the button back and it will work the rest of the day no problem.
Changed keys/batteries also to no avail....
I did take it to the dealer once and they kept it overnight but surprise, surprise, it didn't happen for them...
Old Feb 21, 2021 | 09:27 AM
slefkoff's Avatar
Nissan Leaf
Same here
Old thread but I’m having the same problem with my ‘14 e250. Push button doesn’t work in the morning. Engine cranks but doesn’t start. Pop out the button, use key, and it works. Put button back in and the button will work the rest of the day. Also noticing rough shifting sometimes in the morning but I doubt that’s related (although if it is that’d be something...). Did anyone with this problem ever get it figured out?
Old Feb 21, 2021 | 10:14 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Like was mentioned earlier in the thread... the first non-start with the button could be a red herring. Remove the button and try starting the car with just the key. Does it also take more than 1 attempt to start in the morning with the key?
You should also scan for codes, ideally with a MB-specific scanner.
Old Feb 21, 2021 | 10:43 AM
slefkoff's Avatar
Nissan Leaf
Thanks. It starts on the first attempt every time with the key. No codes with my bluedriver obd. Curious from the other two posters in this thread with the exact problem what they determined it was.
Old Feb 21, 2021 | 10:51 AM
Have you replaced the key fob battery? I think you'll need to find someone with Star diagnostics to further diagnose and run tests on the keyless-go system.
Old Feb 21, 2021 | 11:11 AM
slefkoff's Avatar
Nissan Leaf
Yep, replaced battery and that didn't fix it. You're probably right - need additional diagnostics. Was hoping @Hoover2112 or @stevil555 figured it out for their cars because they're describing exactly the issue I am having.
Old Feb 21, 2021 | 11:34 AM
  #32
Neither has been online since 2019... so I wouldn't hold my breath. All to often someone will join a forum and post about an issue, get some advice and never follow-up or post again.
Old Feb 21, 2021 | 12:14 PM
  #33
slefkoff's Avatar
Nissan Leaf
Yep. Hopefully this will be an exception but I’m not holding my breath. Worth a try though!
Old Feb 22, 2021 | 06:21 AM
  #34
silvermoon1959's Avatar
2014 E350, 1989 560sl, prior 2001 E320, 2008 E300
Keyless Go Issue
Had a similar problem a few years back on my 2014 E350 4matic Mentioned to the service dept at Mercedes and they replaced the Aux. battery (located in the trunk). Covered under warranty which was a surprise.
problem solved
Old Jun 14, 2021 | 09:47 PM
  #35
Joy's Avatar
Joy
Gls63
Same problem with my gls63 2019
Old Jun 14, 2021 | 10:39 PM
  #36
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
float & scan & TSB update fix...
Have you tried to....
1-- Float the two batteries to see if it is voltage sensitive?
2-- Scan the car to see what other modules have been upset with DTC's?
3-- AFAIK KGo works well when the TSB software bug of 4x door control units are fixed (IF your car is indeed affected by this DCU birth deffect)
----> EDITS:
​​​​​​I am going to RE-Read this thread to try and summarize help... mostly about swapping batteries and key being too far.
A friend of the KGo hands-off function is the trunk self-close KICK, that I have just repaired.
My trunk kick motion had been moody since the beginning... sometimes nothing would work, sometimes it would hit you hard in the back of the head like a cheap piece of junk !
The fix is a 5mn repair of module solderless electronic board -
Old Oct 25, 2022 | 07:14 PM
  #37
nyckid's Avatar
e500
So what was the fix???
Old Oct 25, 2022 | 07:42 PM
  #38
KGo
What testing have you done so far, leading you to what?
Fixes vary based on problems.
Part 1: KGo module needs easy soldering. Let's see close up pics of how your module looks.
Part 2: KGo works on CAN data. Scan your car for a survey of errors.
It's a great idea to fix KGo to help your SAM enter low-power sleep mode (crazy KGo >> crazy SAM).
In other word you get a lot of leverage with this simple fix.
KGo is located in trunk above R-SAM.
*disconnect batteries always your 1st step*
Old May 25, 2024 | 01:43 AM
  #39
Bostonslk300jen's Avatar
2016 slk300
Changed batt , auxiliary and under hood.... soldering thing, ok .. please any info? Perhaps I'm not navigating through the site properly on my mobile I did not see any photos or anything in regards to this fix...
TKS
Jen
Old May 25, 2024 | 05:12 PM
  #40
TKS
Jen
Jen, what's going on with your keyless?
Old May 31, 2024 | 02:30 PM
  #41
DeanMassy's Avatar
lexus
If the car wakes up (position 1) when you push the button -- but does not start -- with the key in your pocket, it most likely is because something is amiss with the wireless recognition of the key. Pressing the button a second time will not help the system recognize a key it did not recognize on the first try.
Old Oct 13, 2024 | 05:02 PM
  #42
Cps13's Avatar
As already mentioned by one person above. This issue is caused by a low voltage or old auxiliary battery.
I’ve had the same issue with my S500, charged up the aux battery and it went away.
If your start/stop is also intermittent at the same time as this keyless start issue… this is another sign the aux battery is low voltage.
Old Oct 13, 2024 | 09:20 PM
  #43
you're aware AUX does not generate power... if its flat it's because the supply circuit is bad.
There's a fuse is charge of cutting off supply.
Every chassis's different - Refer to specific chart or inspect/test fuses below 10A.
Old Oct 14, 2024 | 03:02 AM
  #44
Cps13's Avatar
I don’t really know what you mean about the aux not generating power. It’s a battery, therefore it has stored power. The battery is charged under engine braking, and used to power non-essential items. When it gets low, things like start/stop will be affected. Keyless start is one of the things affected by a low voltage aux battery.
Old Nov 17, 2024 | 10:15 PM
  #45
Nor Cal SL55's Avatar
2012 E63 AMG
I have a car that came from the factory with keyless go. The start/stop button is not there, but all the other entrance and keyless go functions work with both keys. How do I know if purchasing a new button will make it work of if the ignition has been changed out?
Thank you
Old Nov 17, 2024 | 11:00 PM
  #46
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Replace the button and see what happens. I think it will start.
Old Nov 18, 2024 | 08:30 AM
  #47
2012 E63 AMG
That's what I've been thinking (new car to me), but I'm wondering if the keys have been changed as well. No gray release button on either key, both are black. I tried the push with finger trick and nothing...
Thank you for your reply.
Old Nov 18, 2024 | 11:27 AM
  #48
2012 E63 AMG
Originally Posted by Plutoe
you purchased a ton of problems and all of your assumptions are correct
Tons of problems like I need to purchase new keys and have them programed or ignition swap out?
Old Nov 18, 2024 | 01:49 PM
  #49
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
I might just by an inexpensive button from E-Bay and see, If the car has key-less go, it will start, it's very likely your button was scratched or otherwise cosmetically unappealing so they pulled it out at the dealer
Old Nov 18, 2024 | 02:20 PM
  #50
TROUBLED NETWORKING...
... perhaps KeylessGo networked ignition was unreliable so key inserted was found to work better.
I've had the laggy keylessG locks but nothing EIS ignition issue.
As far as amazin' body CAN-B:
Right know I suspect my COMAND is silently developing a CAN issue, not sharing its 11 satellites data with the sleepy mBrace/Komo that's consistently upset...) - CMD has some gateway functions, I guess solderless!
5mn soldering after removing 40+ screws.
So nothing is made simple with Bosch networking... complete chassis scan necessary to concider how network strings partially work.
