Full LED question
I'm thinking about getting a 2014-2016 e350 with full LED. The question I have is since I'm getting a used car, does the quality of light in the LED degrade after a few years? (e.g. I've seen HIDs on older cars that are as bright as halogens on newer cars) And if so, has anyone had to replace the LEDs? How expensive are they?
LEDs theoretically do degrade over time, mainly due to the components overheating which creates stress on the component. Keep in mind, LEDs are mini diodes, they are fairly basic components with no moving parts, like a capacitor. They rarely fail. However, they can age if they overheat. In very rare cases, they can fail if they overheat.
Considering the headlamp should have numerous heat sinks to reduce excessive heat, the LED headlamp shouldn't have any major issues. But it is difficult to be certain. Furthermore, LEDs are usually turned on at night, the coolest part of the day.
Generally, LEDs shouldn't have major degradation throughout the life of the vehicle. But here are some things that would likely cause LED degradation:
1. The car's headlamps are on during the day (some drivers turn the lights on for safety). This may have a major effect; the heat from the LED and the heat from the day in a warm climate could cause the diode to experience more wear.
2. The car's headlamps are cycled on and off repeatedly, this may have a small minor effect.
3. Cars that live in hot weather (Las Vegas, Arizona, New Mexico, Texas, MS, Alabama, Florida, things of that like). The higher heat can potentially cause the LED to degrade more and faster.
4. An LED with a design that doesn't have enough cooling capacity. Not enough heat sinks, or too hot of a design without enough cooling can reduce the brightness of the LEDs over time.
The Full LED headlamp probably costs somewhere around $2K to $3K per headlamp per side. So a pair of headlamps probably costs $4K to $6K. These are very approximate prices and dealers mark up tremendously sometimes. A typical Xenon headlamp from Mercedes is around $2K. Headlamps are very expensive parts. Insurance companies hate them because they're often some of the most expensive things damaged in a small accident.
- Nowadays the prices of Led headlamps are not so high anymore.
For 1100€ you can buy a brand new LED Headlamp from Hella.
Ex: Hella Led
But yes... still expensive as hell :-)
