Sponsored by: CARiD
"THUNK" sound shirting out of Park
Old Jul 24, 2018 | 03:27 PM
mellonc's Avatar
E250 Diesel
I get this somewhat loud "THUNK" sound whenever I get the transmission out of Park. it happens when the car is ever so slightly parked up or downhill without the parking brake firmly engaged.
Is this a problem? Dealer can't duplicate it because the the shop floor is perfectly level, of course. Thoughts?
Old Jul 24, 2018 | 03:28 PM
mellonc's Avatar
E250 Diesel
I meant SHIFTING out of Park.
Old Jul 24, 2018 | 06:09 PM
belarus27's Avatar
2010 e550 p2
Make sure you apply the foot brake before you put the car in park.
or
press down the brake pedal , put the car in Park and then apply the foot brake as hard as you can.
those are the ways that work for me.
Old Jul 24, 2018 | 06:10 PM
belarus27's Avatar
2010 e550 p2
Unless there is something is up with suspension parts.
Old Jul 24, 2018 | 06:20 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
I get the same sound in the situations you described and have thought it was normal. Not a common occurrence here in Florida given how flat it is. But when I've parked on inclines I have had success applying the parking brake before shifting to park to avoid the issue.
Old Jul 25, 2018 | 01:27 AM
LemonSqueezy's Avatar
14 550 sedan
You are basically putting a little more stress on the transmission when it's parked on a hill. I live in a city where every other corner is a hill. I will automatically step on the parking brake every time, otherwise I will feel the same clunking sound shifting out of park gear, the sound isn't very pleasant either, sounds like the everything underneath is about to blow.
I shift to park, brakes still engaged, step on parking brake, then disengage brake pedal.
Old Jul 25, 2018 | 01:39 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
same here on GLK350. I step on the brake pedal before i shift into drive, then I pull the parking brake release handle, finally brake slowly off and then drive off.
Old Jul 31, 2018 | 10:22 PM
user 58362638's Avatar
+1 on what everyone said, but a little more flavor to my technique:
Depending on inclination if parked next to curb
Come to a complete stop, turn wheels (inside or outside)
holding the brake, shift car into neutral
release brake slowly until car tire makes contact with curb then press brake again
push in parking brake
release brake slowly again until car settles
then push in park
or
Standard Parking
then push in park
In either case, the drive train isn't under load or tension as the car is in neutral when the parking brake is applied. Never had a "thunk" or any drive train noise using my technique.
Suerte!
Greg
