Anything preventative while changing trans fluid?
Replace the filter of course, and clean the magnets in the pan. Be VERY careful not to get anything like even lint inside the trans.
Once back together you will need to fill with the blue fluid thru the bottom, start the car, shift thru the gears, fill some more, then run the car until the trans pan reads 80 degrees C, and drain until it dribbles.
Not that difficult, just time consuming.
I believe the 722.9 trans requires 'marrying' the conductor plate to the trans with an SDS, which only a dealer can do, so there is no sense messing with the CP.
I think the speed sensor can be changed without SDS, but don't quote me.
