Steering Wheel Upgrade
I cureently have a 2011 e350 wagon pre-facelift with the 4 “spoke”. I do have lane assist, distronic, and heat. I bought a steering wheel with airbag out of a 2014 c63 that has lane assist but no heat which is not a big deal. I took off the old wheel and installed the new and nothing worked.
I can do a chip swap and hopefully everything will work as normal. Instead hacking up my old wheel, can I just buy a new steering column from the facelift years, 2014-2016, put the new wheel on and all button should work??
Since i I have a wagon, I have to get one with rear wiper control and want to have the distronic as well. I found one on eBay from a facelift gl550. Looks exactly the same as mine but updated and signal lever on top be the bottom.
I’ve attaches the pic of the column and the wheel I bought to help. Thank you in advance. I want to try not buying all these parts and not working.
https://www.youtube.com/watch?v=-_wu1KkgoXE
Only thing is that I have an airbag error message that I have to remove. But the hard work is done!!
I've done two wheel swaps before in an older car (Audi) and it was scary - my issue was rewiring a single stage airbag into a dual-stage airbag - you never know if it will explode in your face when you plug it in, OR worse, if it will work at all when you need it in a crash!
And also worry if insurance will cover a claim if they find out you've made a swap... sorry don't want to rain on your parade - I never had an issue
Yes it does feel like a new car 😊! Just have be more careful now, don’t want to ruin the Alcantara in the sides.
No rewiring required, just swapped the chip and plugged everything back in. No issues with insurance what so ever!
Link below will give you an idea how it’s done. But I did not do any striping and rewiring. Just swapped the actual chip.
http://www.flawlessfitment.com/2016/...p-diy.html?m=1
