Driver Seat Not Working E550 2010
Hello
Driver seat buttons on the door are not working (all of them) (Buttons on the side of the driver seat for dynamic all work). Also at night I can tell that the buttons for the driver seat on the door are not lid up. I had someone check the fuses connectors, and I was told its a module under the seat - I guess just looking for some opinions and thoughts. Thanks in advance. I am in , if anyone has some info or knows what to do - I would appreciate it.
Received 4,435 Likes
'71 Pinto
Switch S91/2 is wired into door control module N69/1. Definitive diagnose before replacing parts, have someone pull fault codes using MB DAS (diagnostics). DIY, start with wiring from switch to module see attachment to remove door panel.
Ferris_E550 (09-23-2018)
Thank you for the info and diagram
