Sponsored by: CARiD
W212 Bluetooth audio streaming
Old Oct 6, 2018 | 08:19 AM
Marko2011's Avatar
W211 06"
Hi,
im having W212 2009 year, E class - Avantgard.
I have bluetooth telephony which works okay, but i cant stream music via bluetooth from phone.
I know of secret menu and my bluetooth audio option was grayed out there.
Went to MB service and did software update, and now i cant even see grayed out bluetooth audio option.
Anyone knows how to solve this?
16.600 build, new software update
Build 20.100 - old software, stock software
Old Nov 22, 2020 | 07:54 AM
nostress man's Avatar
E200 2009
And have you find any solution? I have the same problem..
Old Nov 22, 2020 | 08:38 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Which issue? Streaming music via BT or BT option in engineering mode?
As far as I know, you cannot stream music via BT on these till 2016 model with CarPlay. BT only allows phone calls on earlier models.
On our car, we have a MMI BT adapter that allows streaming music via BT. It emulates a connected iPod.
Old Nov 22, 2020 | 09:08 AM
E200 2009
Yes Bluetooth audio streaming... This can be turn on in engineering mode as of 2012 models. I am sure there is a way to tweak the software. Why would they put this option in the software otherwise? OK, it is greyed out but still... No, I bought as well a Bluetooth MMI adapter online. But I am not sure whether this cancels the Bluetooth phone function? Do you know that? Which device brand did you buy?
Old Nov 22, 2020 | 09:16 AM
BoVee and it came with the car. The phone will have two BT connections. One to MB (for phone calls) and the other to BoVee (tune2air for streaming).
It’s a bit clunky, but when listening to streamed music and you get a call... you have option answer in-car via command. One issue, after a call it doesn’t always switch back to streaming BT.
I plan to get a CarPlay unit that will have a better interface.
Old Nov 22, 2020 | 04:56 PM
E200 2009
I see... That's big modification I believe, no?
Old Nov 22, 2020 | 11:34 PM
Ph07's Avatar
2009 initial build W212 E350 AMG PACK
This is possible and worked perfectly fine for me.
Copied from another thread...
Hope this helps
"-End Call + # + 1: opens Engineering Mode
- HU Settings
- HU Parameter
(the following are the settings I put them in)
(1) BT contact plate: Not Installed
(2) LCT: Installed
(3) BT audio: On
(4) Audio Aux: Off (greyed out: not an option)
(5) Video Aux: Off
(6) Navi: installed
(7) BT: on
-back buttonx2
-pull command wheel down
- system reset
- reset - yes
- go to audio, then go to the audio tab again to bring up the drop down menu of audio options, select BT audio and activating audio device comes up, then the audio streaming screen
I have included screen shots of all the important steps (sorry for the poor quality but it was night time and the flash on my phone kept going off) Let me know if I need to clairfy ne thing."
Old Nov 23, 2020 | 05:41 PM
E200 2009
I don't have the HU settings in Engineering Mode... Where are the screenshots by the way? I think this
Old Nov 23, 2020 | 08:32 PM
Toadroller's Avatar
e350 ML350
My 11 E350 sedan lets me stream BT audio and BT phone.
My 11 E350 wagon only lets me stream BT phone.
Weird. I like the idea of an MMI BT adapter, though. Easier than getting to a dealership for a radio firmware upgrade that may or may not work.
Old Nov 26, 2020 | 02:44 PM
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
My 13 550 streams via BT. The 500 just phone with the star trek thingy in console.
Old Nov 26, 2020 | 04:42 PM
cetialpha5's Avatar
It was an issue in the 2010 models, the 2011+ models lets you stream bluetooth from your phone. I use mine all the time. Had the firmware updated a while back. Fixed some skipping problems with bluetooth, use to hiccup all the time, updated fixed that. The 2010 could be enabled though, had to go through some hoops to get it working. The W211 wouldn't let you stream music though, only phone calls through bluetooth.
Old Nov 27, 2020 | 12:27 AM
pb39374's Avatar
2010 E350 4Matic sedan
I have the 2010. All I had to do was go to the dealer and get a software update. And now it works just fine. The update also enables the Boost for the volume.
Old Nov 27, 2020 | 12:33 AM
cetialpha5's Avatar
That's the hoop I was referring, didn't work by default, either had to go through the hidden menu or have the dealer do it.
Old Nov 27, 2020 | 12:38 AM
pb39374's Avatar
gotchya
Old Dec 18, 2020 | 12:57 PM
MKY's Avatar
MKY
2016 GLE 450 AMG COUPE
Audio Bluetooth
The 2010 E-350 100% allows music via bluetooth. I been using it for last 5 years.
