2014 Wagon navigation woes-wrong location
Hi my wifes wagon recently developed a strange issue. The navigation map is completely in the wrong location. It is showing a location several miles away in a different city. Nothing has happened like any time in a shop, it just seemed to happen out of nowhere. Is there a way to reset this? again 2014 W212 Wagon.
thanks. if this is easier to respond: neal (dot) friedant (at) gmail (dot) com |
You could try soft reset, hold “on” button for 10 seconds or so. If this fails try reloading map data if you have DVD + activation code. Worst case scenario GPS antenna and/or connection failed best to have someone pull fault codes before going further.
https://cimg5.ibsrv.net/gimg/www.mbw...84d2723f15.jpg |
Hope that works for you OP. I recall another thread on here about GPS issues that required a new head unit. https://mbworld.org/forums/e-class-w...on-update.html
