E350 w212 Interior Temperature Sender
Hello everyone I’m looking to see if someone could tell me where the interior temperature sender unit is located please on my W212 e350 ? I have a fault code listed for this item and after clearing the code it’s still coming back so clearly a issue.
Thank you
Thank you
Received 4,446 Likes
'71 Pinto
Sensor part # 2118300272
Wenglish1984 (11-01-2018)
2012 E350
Konigstiger - Are you able to find part # for the 'other' W212 interior temperature sensor (the one in the overhead console)? Mine is bad, I removed it, it is slightly different from the part you listed here for the in-dash temp sensor, and the numbers on mine don't match anything, maybe it is aftermarket.
Received 3,652 Likes
MY'14 W212 M276 3.5NA @60kMi
Sensor ok... LIN network initialization not so ?
Drew, the "Temp sensor" you're dealing with is hosted inside the OCP. I have the same issue with it reporting junk data to the Air-Con "AAC Module".
Replacement did not cure that issue.
I run a properly resoldered AAC controller.
So we are in the same boat with this issue.
OCP reports both over CAN and simple LIN ... at this stage I am thinking LIN thresholds need to be retrained using Xentry initialization process.
I believe LIN communications are impacted by unreliable power supply levels from the shared (once painted) GND eyelets.
