Exterior Door Handle Broken
W212 e350 Bluetec
2013 W212 E350 BlueTec
Driver side exterior door handle come out but does not return on its own. Must be forced back in. When it comes out it does not unlatch door. If you open the door from the inside it works just fine.
Any ideas what I need to do to fix this issue.
Well you'll have to pull the door panel and get in behind the exterior handle to identify the exact issue. Sounds like the handle latch/return spring has broken or come loose from the door latch somehow.
