Reseting Errors with Battery Disconnection
I've had my engine light come on and after diagnostics it turns out to be a faulty MAF sensor. Today i've replaced it with new MAF sensors, but the engine light is still on and the car won't leave limp mode..
I've read up that disconnecting a battery will wipe the errors which will turn off the engine light and possibly my car will even leave the limp mode, so my question is:
1. Can I disconnect the battery on my car, and if so will this clear the errors?
2. Do I also have to disconnect the auxiliary battery, and just the main on is fine to wipe the errors?
3. Apart from wiping the errors, will this cause me issues apart from losing all user settings?
My car details:
Mercedes Benz 2011 E350 CDI
Your help is much appreciated guys!
Thanks!
I replaced MAF on W210 and having no scanner - I cycled the ignition to start. Counted 7 starts in about 10 seconds till CEL went out
But the code will stay as historic one in car memory till you clear it.
It can get annoying when you buy used car and find 30 or 50 historic codes on it.
I'm wondering about the limp mode, is this induced the error code sitting there so once cleared it will run normal again?
You need to have all the codes read, as the TCM (Transmission Control Module) has it's own set of codes. Is your ESP/BAS light on? If so, try replacing your brake light switch. Common failure that can trigger a limp mode along with ESP/BAS.
The mechanic suggested it's a MAF sensor, that's the root issue of all those errors, or atleast we should tackle that first...hence i've replaced it.
Video link showing my issue before MAF replacement, although it drives the same after it..
No, but what could the battery be affecting so much that it'd put the car into limp mode?
Is your accelerator pedal harder than usual to push down? I was thinking brake light switch, but that usually throws ESP/BAS error too and you don't seem to have that.
You should have them cleared with MB-oriented scanner and then recheck.
Take picture of scanner screen to avoid confusion.
