High beam not working
It is LED that are using the same bulb and "gate" who makes it low or high beam.
Both systems are pretty complicated and being relatively new, not much experience.
I would check what type of headlights you actually have and.... read the manual.
I've replaced my HIDs and highbeams with plug n play LEDs. Not only are they far brighter they also have less current draw for our ageing switches.
FYI
that looks pretty good, crisp cutoff line. drive to about 5 feet from the wall, put some masking tape at the top of the left and right ligth cutoff, then drive about 20 or 30 feet back assuming flat/level, and see how far the cutoff line drops... it should be slightly below your tape marks, NOT above.
