2014 E350 W212 N0 Audio / Sound
Guys I may be stupid( I should have stayed away from it ), I was playing with the Engineering Menu yesterday to enable AUX function( to enable apple car play) . I turned off the MOST in the TGW menu and Turned it Back ON to enable the AUX in the HW setting .. everything was okay at that time , when I switched off the car and restarted , I don't have any sound from audio system any more .
All the functions works as expected ,, No sound .. Need some help here to reset or entering the correct option in the command unit ...
Vijay
Vijay
Yes , regardless of source no sound from the system , all the sources are getting regonized , Bluetooth , DISC and SD and they are playing according to the display , Can someone share the default value and so I can set everything back ?
Vijay
Vijay
Solved It . At last !!!!
)) and enabled the AUX option also ...
Steps to Enable the AUX input on your w212 E350 command unit
1.Enter to Engineering mode -- > Press ( end call + 1 + #)
2.go to option 7 HW setting
3.Go to menu MOST -- > Turn the MOST OFF
4.Go to TGW menu enable --> AUX to ON
5 Go to MOST menu again - Turn the most ON ( Important -- change your Amplifier to External -- when you turn off the most in step 3 it automatically the changes the amplifier option to internal ) -- where I failed ..
Go to System reset (9) and reset .. You are set , now you can see AUX as one of your audio options ...
Vijay
Vijay
pamiboy (01-06-2019)
