Wheel and tire question
2010 W212 E350 4matic sedan P1
Looking at a staggered set of AMG 19 inch rims off a W222. Found these with tires but was needing to know if the rims would fit my w212 4matic? Also max tire size that would fit for a staggered setup for my 4matic. Thanks
edit*
8.5 x 19 offset 38 | 9.5 x 19 offset 38
245/45 R19
275/40 R19
i think those are the current tires sizes on them.
I don't believe that the $MATIC suspension and drivetrain is set up for Staggered configuration. The 19" part you might get away with but probably NOT the staggered. Fronts looks close 245/40R/18 normal and 245/45/R19 on this set. Too bad this set looks like a good set of rims. I might have tried this if I didn't get my Enkei Hajain's from Tire Rack and Michelin Pilot Sports. This set looks good for RIMS only. I prefer Michelin's but if this set had decent tread I wouldn't toss them.
You can run staggered on 4Matic. You just need to keep the circumference, rolling rate very close from front to rear. E63 is 4Matic staggered, I run staggered setup on my E550 4Matic in the summer.
pierrejoliat (06-23-2020)
Received 1,736 Likes
1922 Ford Model T / no OBD
It is Rounds Per Mile that maters in staggered tires matching.
MB never gave solid tolerances, but experience says that ESP will accept 3% differences and then a discotheque on the cluster start flashing.
Now with all those threads about cracks on 18" wheels why somebody would like to put 19" ?
Got the stock 18s currently and no cracks just a lot of curb rash thanks to the wife. Been wanting rims for a while now and wanted something a little bigger. After a lot of searching that tire size won’t fit my car. 245/35/19 front and 285/30/19 rear or 275/30/19 rear are my choices for staggered. Talked to the guy I’m able to pick up the wheels only for 500. Just got to drive 3 hours to pick them up.
John, I have only had the Pilot Sport's on the E350 for a little over 200 miles but based on previous vehicle and reports I have high confidence in their reliability and durability. One drawback that I didn't expect is when on staggered wheel set ups the mileage treadwear warranty drops to half (22.5K instead of the normal 45K) Costco stands by them and even though the treadwear warranty may be expired as they see it...If their is legal tread they will patch/plug and repair as able. I never had Continentals my buddy in PACNW had them for his Taurus SHO and seemed to have good results. His only reason for the P/S was a contractor in a hurry to catch a flight at PDX dropped a box of roofing nails. The company owner fessed up but no Continental DWS available. They paid for a full set of P/S 3's and he was happy. I switched to them after my Eagle F1's had cord showing at state safety inspection. Automatic Fail, once they see cord, they stop right there. Usually caught before charging in fact in my case it was caught before any paperwork was started. I got a new set of Enkei rims from Tire Rack and they fit nice. Flared out a slight more than I am used to but aggressive and sporty looking without being over the top. I am not good at photos on this forum yet but if you send PM with email address I can send some. Set of four Enkei Rims 18" for just a tad north of $960 including tax, S/H. Tire Rack has been very good to me over the years, they notified me of damage on one of them during warehouse inspection. They shipped from another warehouse and arrived within a day or two of the original order. No immediate rush because I was waiting for the Pilot Sport's to arrive at Costco. Tires arrived, Costco Install took about 90 minutes NTB alignment a couple of days later took about 45 minutes and I am on my way. I took advantage of the .01 per tire installation at Costco so the $70 Michelin instant rebate and the .04 installation was a good selling point. The only major curveball in the budget was the TPMS Sensors. I went all new rims, tires, TMPS sensors and alignment. Take a Guess at Costco price for TMPS Sensors...…..waiting.....waiting.....wait for it...….$44.00 each. I hate to ask what dealer cost would be. Yes almost $2000 for tires, rims and TMPS sensors but I was able to save $150. I had a alignment package from my Taurus SHO, five year nationwide plan. I still had two years left and the plan allowed a ONE TIME transfer to another vehicle. Guess who saved $150 at NTB yesterday......This Guy!!
Yes, 0.1% is basically identical diameters. I used 255/35-19 front with 285/30-19 rear (on former '14 E550), identical to E63s factory setup. The difference is 1% (or 0.3") which is what MB's tolerance is. No issues.
265/35-19 3.7in 13.2in 26.3in 82.6in 767 0.0%
285/30-19 3.4in 12.9in 25.7in 80.8in 784 -2.2%
I would NOT run this spec on 4Matic.
Crna Mechka (02-04-2019)
Received 3,399 Likes
2012 CLS63
I'm currently selling some 18's for 2k per set. HRE wheels. Have two sets that would fit.
Thanks. I guess I'll have to pass on them. How do you come to these calculations btw if you don't mind me asking? Would be helpful to know for later down the road as I shop around.
There are many tire size calculators online. Plug your 2 tire sizes in here to compare specs between them.
For those wishing to perform calculation themselves, the formula is:
(((section width * aspect ration) / 2540) * 2) + wheel's diameter
for example 255/35-19 tire's diameter is
(((255 * 35) / 2540) * 2) + 19 = about 26.03"
And again, generic calculations with tires come with huge error as tires are manufactured with very loose tolerances.
Only comparing rpm posted by manufacturers gives proper comparison.
275/30-20 3.2in 13.2in 26.5in 83.2in 761 -1.0%
Seems this setup might work if accepted range of tolerance is in fact 1%.
KEY08 (05-22-2019)
pb39374 (01-19-2020)
Years ago I put $500 a piece tires for our ML. To protect my investment, I added TPMS with plug-in control panel. When I was out of town, the alarm start beeping. DW solved that by pulling the plug on panel.
The tire survived.
2012 CLS63
I'm fairly certain only 2.4 % of women actually care about cars, perhaps even lower
pb39374 (01-20-2020)
Would this set up work for my 2010 e350 w212 4matic sport?
Yes. I see no advantage to the wider 255 tire over the 245, but your call.
