Coming over to the E class, questions about COMMAND
1)
Does the E class show the turns if your using the satnab in the middle screen of the clocks?
2) Does the screen in the middle of the clocks also show what radio station/ track your on?
I am coming from i-Drive which shows you on the screen, and on the clocks where it will count down how many yards your away to turn left/right etc.
Many thanks!
luke
COMAND for has single screen where it shows stuff.
What it shows depends on what functions you are using.
With NAV you get full map and options for POI. Directions come up as yo uget to them.
Note each function NAV RADIO etc also has an AUX screen under speedemeter if you set it via stgeering wheel.
Suggest you go test drive a E class and play with COMAND
