Sponsored by: CARiD
Gas Pedal Tuning Device
Old Apr 4, 2019 | 12:36 AM
ChrisB's Avatar
1999 SL 500 & 2011 E 550 4Matic
I had read on this forum recently - that there is an accessory that can be purchased & mounted on the gas pedal that gives performance level selection.
I did not make notes .. and have lost track of where that reference was.
Any one know what I am talking about?
Old Apr 4, 2019 | 06:27 AM
pb39374's Avatar
2010 E350 4Matic sedan
its called Sprint Booster
https://www.sprintboostersales.com/S...r_V3--SPRME020
Old Apr 4, 2019 | 06:46 PM
Leonardick's Avatar
2013 E550 4MATIC
https://www.racechip.us/shop/mercede...ml#-xlr-anchor
Old Apr 5, 2019 | 08:13 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Be aware, however, that these devices do not really "add" any power or performance. They only cause the throttle to open more quickly with less pedal motion. Full throttle is still the same full throttle. You just get there with less motion of your right foot.
Old Apr 6, 2019 | 10:05 AM
Leonardick's Avatar
2013 E550 4MATIC
Indeed, here iis what exactly what was describing on theirs website:
"The RaceChip XLR is installed between the throttle pedal sensor and the engine control unit. Depending on the XLR’s tuning stage, it either amplifes or reduces the signals sent by the throttle pedal sensor in accordance with characteristics defined by our engineers. The effect is that you can choose how your car reacts to your throttle inputs.
2 Sport (S, S+) and 2 Race stages (R, R+) sharpen throttle response, speeding up the engine’s reaction times, making it as reactive as even a sportscar’s. 2 Eco stages (E, E+) slow down the engine’s reaction to movements of the throttle. In heavy city traffic and on long journeys, this can help you reduce fuel consumption. You can select N if don’t want or need to use XLR, and your car is back to stock tune.
RaceChip XLR is available for any car equipped with an electronic throttle, regardless of whether the engine is naturally aspirated, turbocharged, supercharged, electric or hybrid."
