Sponsored by: CARiD
Exhaust Mounting Brackets
Old Apr 10, 2019 | 12:46 PM
apachecai's Avatar
2010 E550 Base & 2011 GLK350 4Matic
Hi, can anyone confirm if the 2010 E550 Sedan base has the exhaust mounting brackets right below the torque converter housing? I was draining the transmission fluid out of my TC and found out both exhaust mounting brackets are missing. I purchased the car last month. So the only thing that's holding the exhaust at the front end is just the exhaust manifold. Should I order the bracket and put them on? Thanks a lot! (The two attached pictures were from W204, not W212)
Old Apr 11, 2019 | 12:08 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by rodrigra94
exact same bracket on my 2005 C230 sedan (W203) was rattling I put the car on a lift and noticed that I lost one of the two bolts from that bracket. Can you please identify the part number for the bolt, if not, possibly the bracket itself
Assembly consists of plate 1294900044 (130 in diagram), bracket 2104926241 (90), nut 1201420072 (140), damping plate 2024920718 (110), shim plate 2024920018 (115), and M8x30 bolt to bracket 910143008003.
Old Apr 11, 2019 | 12:20 PM
'71 Pinto
Originally Posted by apachecai
can anyone confirm if the 2010 E550 Sedan base has the exhaust mounting brackets I was draining the transmission fluid out of my TC and found out both exhaust mounting brackets are missing
Should be there: shim plate 2034920518 (50), right bracket 2044923141 (70), left bracket 2044923041 (60), nut 0029901654 (80), front bracket 2044900044 (90), and M8x35 bolts 910105008014 (110).
Old Apr 12, 2019 | 01:14 PM
apachecai's Avatar
Bracket Installation
konigstiger, thanks for the response. Can you advise the installation order of part 90, 60 & 70, which one mounts to the TC housing first, second and last? Part 90 seems to have 4 holes, so do I need 4x 110 bolts? thank again.
Old Apr 12, 2019 | 02:16 PM
'71 Pinto
Post 2 is for 05 C230, 3 (M273) is 10 e550 your photo & the diagram should be self-explanatory.
