Sponsored by: CARiD
Right mirror "feature" in Reverse gear?
Old Apr 29, 2019 | 10:52 PM
Edward993's Avatar
2014 E350
We have a 2016 E350, and the right mirror turns upward when you put the car into reverse! ...upward ...what, like I need a view of what's higher up when backing the car??!!!!
So I went through the entire dash menu system and can't find anywhere to turn off this "feature" ...help! Either to kill it, or to tell it to turn downward in reverse, duh!
Edward
Old Apr 29, 2019 | 11:07 PM
Arrie's Avatar
Edward
With the reverse gear on after the mirror moves adjust the mirror to position where you want it to be on reverse gear, like to show down around the right rear wheel area or so. After this when you select drive the mirror will return to the memorized driving position and when you use reverse again the mirror will turn to position that you selected above.
The feature works only if you have selected the right side mirror from the buttons last. If you press the driver side mirror button it disables this feature, which answers your question how to disable it.
Old Apr 30, 2019 | 07:16 AM
raja777m's Avatar
2014 E350 4M Diamond Silver
Edward
if you permanently want to disable it (until you enable it back again), turn off the engine, use the keyfob not the button, put it in ignition mode, select the right mirror, put the vehicle in reverse and adjust the mirror to where you want.
Put it in park, go out of the car with the keys and come back again. This should reset it.
Follow the steps again, in case you want to enable it in the future.
Old Apr 30, 2019 | 09:48 AM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
I just re calibrated mine, it was easy to do.
The fold ins I have on off, no need for this where I go
Old Apr 30, 2019 | 10:04 AM
DFWdude's Avatar
2016 E350 Sport
I can see how this happens. The tilt-down mirror stays in this position until one selects "D" and drives off. The mirror does not return to the driving position for several seconds later.
IF one finishes reversing (still in "R"), looks in the mirror, then adjusts the mirror to the driving position before selecting D (ie., mid-cycle), then the mirror will be re-trained and behave differently the next time reverse is selected.
Especially if you have more than one driver, all should understand how the feature works. The mirror only does what it is programmed to do...
Old Apr 30, 2019 | 11:42 AM
RA72825's Avatar
You could always read the manual.
Old Apr 30, 2019 | 12:41 PM
nota_amg's Avatar
2013 SL550 BiTurbo
omg...really?
1) Select right mirror button
2) Put in reverse-mirror will move...
3) When mirror stops moving, Move mirror where you want to look
4) Put in park-mirror goes back to static setting after 3 seconds.
If you want to disable, either just push the left mirror button, or you can turn off in the cluster.
Old Apr 30, 2019 | 08:42 PM
Arrie's Avatar
Originally Posted by couldnthinkaone
omg...really?
Didn’t I say just the same in my reply?
Old Apr 30, 2019 | 09:18 PM
Edward993's Avatar
2014 E350
OK, got it. Recalibrated it to tell it to look down. Thanks!
I know, seems lame on my part, but whatever it was I was doing to try and "train" it to look down in reverse wasn't "sticking". Yes, lame on my part, but thank you for clearing it up. It works properly now
Ed
Old Apr 30, 2019 | 09:22 PM
nota_amg's Avatar
2013 SL550 BiTurbo
My bad...
QUOTE=Arrie;7745510]Didn’t I say just the same in my reply?[/QUOTE]
Yeah, I see that now, sorry. My frustrations are not with you though. The OP is either a troll, or has a memory deficiency. He asked the exact same question 10/05/2016. He was answered, and acknowledged the answer...anyway, no big deal I guess. Scroll down, the related thread was just below this thread earlier...smh
Old Apr 30, 2019 | 09:26 PM
RA72825's Avatar
Werd
Old May 5, 2019 | 12:55 AM
Edward993's Avatar
2014 E350
I am the OP. So I am either a troll or have memory deficiency? Hmmm. Certainly not the former, so perhaps the latter. Thank you for your kind words and generous spirit.
Edward
Old May 5, 2019 | 07:51 AM
nota_amg's Avatar
2013 SL550 BiTurbo
Well, here ya go...notice the date?
Maybe this will refresh your memory???
Old May 5, 2019 | 11:26 AM
Edward993's Avatar
2014 E350
Congrats, man. Did I not just say I had forgotten in post #12? And did I not just admit a lapse in my thoughts in post #9, not to mention feeling "lame" about it? You are a super sleuth, to be sure; well done. Your behavior here is a testament of your contribution to the board as well as a true reflection of the type of person you are. Be well.
Edward
